This Little John pressure regulator next to the street just doesn't sit right with me. They are connected to a 100 psi high pressure gas line at the street. My concern is a driver or snow plow hitting one. I inspected one of the houses with one of these on the street. The local gas supplier and code officer says they are OK.
Rick Kie |
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You can make any recommendation that you find prudent to your client but don't expect the seller to fix something that the gas company and code official condone.
prichardson is a non-member guest and is in no way affiliated with InterNACHI or its members.
where it is least likely to be subject to damage (riser protection is required if the set can be damaged by vehicle traffic or other activities); This is the wording from PSNC, our local Natural Gas Supplier |
Ricky ~
I totally agree with both the other inspectors. Jim Kolke www.chicagohomeinspection.biz www.pinnaclepropertyinspection.com www.aurorahomeinspection.info www.chicagocondoinspection.info www.chicagoinfraredhomeinspection.com www.wilmettehomwinspection.com www.skokiehomeinspection.com www.barringtonhomeinspection.com www.lagrangehomeinspection.com www.oakbrookhomeinspection.com www.napervillehomeinspection.info |
| Shut off valves required? | jcahill | Plumbing Inspections | 11 | 9/2/08 1:07 AM |
| Neutral bus bar failed inspection | Greg Moritz | Electrical Inspections | 18 | 1/19/08 1:53 PM |
| Main Electrical Shut-off? | jpassailaigue | General Inspection Discussion | 10 | 3/24/06 2:19 PM |
