Old 6/29/07, 11:02 AM
Calvin D. Cowles's Avatar
Calvin D. Cowles Calvin D. Cowles is offline
Default Gas meter clearances
What is the UPC clearance requirement for gas meters?
Old 6/29/07, 12:02 PM
Default Re: Gas meter clearances
Hi. Calvin;
NFPA 54 5.7 states that gas meters shall be located readily accessible for examination, reading, replacement, or necessary maintenance.
Also, gas meters shall be located at least 3 feet from sources of ignition.
Not sure what other codes would apply to this, but I would check with your local gas Company regulations for this one.
Hope this helps.
Marcel
</IMG>
Old 6/29/07, 12:11 PM
Thanks Marcel. I found the 3 ft. requirement as well.
When in doubt...report it right?
Exterior Service Disconnect Clearances? rcramer Electrical Inspections 18 7/28/07 1:12 PM
City electrical inspector says move the meter and panel cbottger Electrical Inspections 9 4/4/07 8:59 PM
Panel and Meter jwilliams7 Electrical Inspections 10 6/21/06 5:49 PM
