Flex connector feeding gas fireplace shut off valve, copper pipe feeding from shut off valve to gas insert in fireplace. Info I have is no copper pipe / fitting but cannot find what code address's this. Does anybody have idea.. thx..
It's up to your utility company whether you can use copper. . .
Copper is a very popular piping material to use with LP.
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Bonding both hot and hold supply pipes | kshepard | Plumbing Inspections | 22 | 5/4/08 8:00 AM |
| Bonding Piping 101....Good To Know ! | pabernathy | Electrical Inspections | 37 | 4/28/07 11:25 AM |
| plastic piping? | Scott Schultz | Plumbing Inspections | 5 | 3/28/07 1:40 AM |
