Old 9/17/07, 4:04 PM
Ron Chorey II's Avatar
Ron Chorey II Ron Chorey II is offline
Default gas piping size
I have a question on gas piping. I have 2 packaged AC units(Comfortmakers). The gas piping to both of them, which are on the roof, is 3/4 inch, then there is a 3/4 to 1/2 inch elbow and then the 1/2 inch shut off valveand then a 1/2 OD inch flex pipe which is 3/8 ID. Is this to small for a 100,000 & 60,000 BTU furnaces in the Packaged systems? I did not measure the distance to the systems, the 60000 BTU furnace is approximatley 100 feet, the 100,000 btu furnace is approximatly 50 feet away from the main gas line. It just seems that a 3/8 ID pipe may be small. Can anyone give any input?
thanks
gas-piping-size-hpim1500.jpg   gas-piping-size-hpim1501.jpg   gas-piping-size-hpim1502.jpg   gas-piping-size-hpim1503.jpg
Old 9/17/07, 5:33 PM
Default Re: gas piping size
If they work fine, why question it?
OR
The gas company or a qualified HVAC professional should be able to help with your question. That's who sized our service lines before installation.
Larry Kage, CMI
231 929 3525
Old 9/17/07, 5:34 PM
Michael Larson's Avatar
See sizing tables but it should be OK if I understand your post correctly. Sizing Tables
Old 9/17/07, 7:48 PM
Jeffrey R. Pope's Avatar
This is the general "rule" for appliance connectors. . .
Appliance connections shall, at no time, have a diameter less than that of the inlet connection to the appliance as provided by the manufacturer.
If the connector is smaller than the inlet of the appliance, it should be changed.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/17/07, 7:59 PM
I agree but Rom didn't share with us the size of the appliance piping.
Old 9/18/07, 9:25 AM
Thank you for your input. The pipe sizing of the appliance is 1/2"
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Bonding both hot and hold supply pipes kshepard Plumbing Inspections 22 5/4/08 8:00 AM
Bonding Piping 101....Good To Know ! pabernathy Electrical Inspections 37 4/28/07 11:25 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
