O.K. Show of hands.
Scenario... Copper gas supply line passes through block wall, no insulating sleeve. I know many of the Northerner's do not allow soft copper for gas, but for all others, how many of the HI's would write it up and why? </IMG> Bill Corbett C.H.I. Magic City Inspections LLC InspectingtheUnexpected.com
Piping needs to be protected from physical damage.
The chemical makeup of mortar products attack copper
Please tell me more.... |
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Must be a location thing. |
![]() Note the leak in line at mid point. |
That is right Charlie, the lime in any and all masonry reacts with copper and causes little pins holes (sometimes in wall cavities). Get the right fuel to air mixture, unplug the vacuum and then
Any type of pretective sleeve where in contact with concrete, brick, block et cetera will be sufficient, at least in this neck of the woods.
David,
You're welcome. It's a great site for all things copper. |
| Gas supply lines to water heaters. | dkoehl | Plumbing Inspections | 5 | 3/6/11 2:07 AM |
| Supply Lines | dbreen | Plumbing Inspections | 10 | 11/22/06 7:49 PM |
| supply in slab or walls? | jeubank | Plumbing Inspections | 1 | 7/8/06 10:36 AM |
