Old 8/31/07, 2:59 PM
David C. Macy's Avatar
Default Gas unions
Is a gas union allowed inside the furnace cabinet?
Old 8/31/07, 3:15 PM
Jeffrey R. Pope's Avatar
Default Re: Gas unions
I know of nothing that would prohibit it.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/31/07, 3:30 PM
The union was leaking and I just wanted to make sure that it is allowed in the cabinet.
Another question pertaining to unions. There was no union on the water heater line. (Or none that I could see) There is supposed to be one correct?
Old 8/31/07, 4:17 PM
phinsperger's Avatar
With a flex line there would be no purpose for a union.
By the way. I do not see a dirt leg or a shut off valve for the DHW. I see a valve for the stub out only.
Old 8/31/07, 4:56 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
What the general consensus with drip "dirt" legs? Do you recommend them on any furnace/water heater where they are not present regardless of age? Do you recommend them on newer ones in which they should have one based on current code but do not? Basically, do you recommend retrofits?
Old 8/31/07, 6:45 PM
I don't recommend them at all, because our utility company does not require them. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/31/07, 7:37 PM
maybe not due to moisture in the gas but what about the sediment that can develop in the line over time? Also, what if you have a unit that has the "install drip leg" label and one is not installed?
Old 8/31/07, 8:06 PM
If I saw such a label, I would certainly recommend installing one. I have never seen such a label. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/31/07, 8:41 PM
Don't know about you guys, but I prefer hard pipe.
to use the right techniques for flare fittings.
Flared fitting with flex hose might be alright, but when it is kinked like in the picture, it make me wonder if it is right.
Marcel
Old 8/31/07, 9:13 PM
gbeaumont's Avatar
Hi to all,
David, nothing to do with the piping issue, but I would suspect a heat exchanger problem based on the corrosion just to the left of that burner bar
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 8/31/07, 10:11 PM
dchew dchew is offline
Unions or bushings in concealed locations are prohibited according to my Code Check. Personally, I wouldn't get too bend out of shape over it if it's tight. However, unions tend to leak more often than threaded couplings.
Old 9/1/07, 2:20 PM
Charley L. Bottger's Avatar
That is correct but the furnace cabinet with excess door is not considered as a concealed area.
This very true I find more leaks on unions than most anyother fittings but try to change a gas valve with a coupling in place of a union and you will be using a sawsall. I have observed that to many fitters will use a union to compensate for a misaligned pipe and just pull the two ends together with the union which most useally leads to a leak.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 9/1/07, 2:53 PM
Roy D. Cooke, Sr's Avatar
I could stand corrected but I think the drip leg is left over from whem they used to manufacture gas from coal ,hence the name coal gas.
http://www.zetatalk.com/energy/tengy112.htm
They used to cooke the coal and coal gas had a lot of moisture in it the left over from the manufacture was coke and this was sold to people to heat their homes,
We used it when I was a kid last century and it was alot cheaper then coal not as much heat.
......... Cookie
Old 9/1/07, 4:02 PM
David P. Valley's Avatar
Drip legs are required on all black iron gas supply lines in Massachusetts. I hardly ever find a drip leg on flex piping though. I call them out on black iron piping only.
I agree with Gerry on the furnace. There's signs of flames shooting out of the burner area. This issue may have been corrected already, but it still needs to be noted.
Usually when I find these signs, I shut the unit down and watch it fire up. Then write up my results.
Old 9/1/07, 4:27 PM
Flexible appliance connectors are the preferred method in this state. When I see a complete "hard-pipe," I will always recommend upgrading. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Grounding at meter nbhi Electrical Inspections 5 7/23/07 10:55 PM
