Old 2/4/11, 7:42 PM
Sean Fogarty's Avatar
Default Gas water heater in bedroom closet
What are the rules for gas WH in bedroom closet? Code requirements please.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/4/11, 7:52 PM
Wayne B. Wilson's Avatar
Default Re: Gas water heater in bedroom closet
G2406.2 (303.3) Prohibited locations.
Appliances shall not be located in, or obtain combustion air from, any of the following rooms or spaces:
1. Sleeping rooms.
2. Bathrooms.
3. Toilet rooms.
4. Storage closets.
Exceptions:
1. Direct-vent appliances that obtain all combustion air directly from the outdoors.
2. Vented room heaters, wall furnaces, vented decorative appliances and decorative appliances for installation in vented solid fuel-burning fireplaces, provided that the room meets the required volume criteria of Section G2407.5.
3. A single wall-mounted unvented room heater equipped with an oxygen depletion safety shutoff system and installed in a bathroom, provided that the input rating does not exceed 6,000 Btu/h (1.76kW) and the bathroom meets the required volume criteria of Section G2407.5.
4. A single wall-mounted unvented room heater equipped with an oxygen depletion safety shutoff system and installed in a bedroom, provided that the input rating does not exceed 10,000 Btu/h (2.93 kW) and the bedroom meets the required volume criteria of Section G2407.5.
5. Appliances installed in an enclosure in which all combustion air is taken from the outdoors, in accordance with Section G2407.6. Access to such enclosure shall be through a solid weather-stripped door, equipped with an approved self-closing device.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 2/4/11, 8:30 PM
James E. Braun, CMI's Avatar
I never worried it about it much. I just tell the buyer, everbody needs a good nap every once in awhile.
Old 2/4/11, 8:39 PM
Bob Elliott's Avatar
Not a good choice but if the door is sealed and gets makeup air from outside there is no issue.
Also make sure there is a drain pan and C/O detector.
Old 2/4/11, 8:45 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
James I am ashame of you.
It sures shows how much we as CMIs do not care about codes.
I don't care if the code said you could sleep with the Hot Water Tank. You will never convince me it is safe even if it is direct vent.
And you are right every one does need a gooooooooooooooooooooooooood sleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep sometime.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/4/11, 9:44 PM
Guess you never lived anyplace with space heaters.Why scare people based on unwarranted fears.
Old 2/4/11, 9:52 PM
James H. Bushart's Avatar
Not necessarily true. If the door is sealed and it gets combustion air from the outside...there is more to inspect and report on. It may, in fact, be a very deadly issue.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 2/4/11, 10:05 PM
Sure if not done correctly with the right amount of openings and lack of a good C/O detector.
People can die if it is in another room also remember.
Remember I am in Chicago and many people live in one room studios however every year there are a few cases when you read about people that get sick or die from C/O and you know what.
Almost all the time the furnace is down in the basement.
Old 2/4/11, 10:30 PM
KEVIN WOOD's Avatar
I was an installer of space heaters before becoming an Inspector.
Also was a Oil burnerTech,Oil tank installer,Hot water tanks,Fireplace, chimneys, Wood stoves and HRV.
I have had some training in Gas inspection and certificate. I have installed appliances but have no GAS Ticket.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/4/11, 10:45 PM
OK so I can assume that you refused to install space heaters out of concern for you customers right?
As for me I need no gas ticket and create plenty.
Old 2/5/11, 1:28 AM
Tim Spargo's Avatar
I had a brand new home to inspect yesterday... it was a sealed hallway closet and NO high or low vents... at all for the gas furnace. That was a first... I have found several clogged with insulation etc... but never without any vents at all. My only thought was someone had confused requirements with electric.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 2/5/11, 12:17 PM
IRC 2009
M2005.2 Prohibited locations.
Fuel-fired water heaters shall
not be installed in a room used as a storage closet. Water heaters
located in a bedroom or bathroom shall be installed in a sealed
enclosure so that
combustion airwill not be taken from the living
space. Installation of direct-vent water heaters within an enclosure
is not required.
865-256-5397
Old 2/5/11, 4:54 PM
clambert2 clambert2 is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
The newer high efficiency units get all their combustion air from the outside via the plastic PCV vents, no need for combustion air vents in the closet. Direct vent principle
Old 2/6/11, 12:53 PM
Tim Spargo's Avatar
I hear ya there Chuck, more *stuff* to look for these days.
This one was B Vent... basic induced style. Was a bank owned where the builder had started in 06/07 and the bank "finished it up"
The type I've seen that you're mentioning have 2 PVC vents, are you indicating that you've seen a single vent/intake pipe on a closet furnace, similar to a Direct Vent furnace on a wall installation? Would be a fairly large vent if I were to "matrix" the size vents I've seen on even a 25K DV type.
Tim Spargo
661-317-5770
Old 2/6/11, 1:41 PM
KEVIN WOOD's Avatar
Did one a couple weeks ago with PVC and a rubber connection that had loosened of at the induced forced fan. This is common because when installed the clamp is tightened and then becomes loose if not tighten correctly. Most people don't understand where to install the CO detection and think about fire alarm installation being the best location. Not so, "this is what can kill you".
Gas and carbons act on pressure they are heavier than air and they seek out areas to hide in a basement never setting of detection until it is too late.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Gas Fired Heater Flue Pipe Runs Through Bedroom Closet bwilliams Inspecting HVAC Systems 7 11/10/08 9:56 PM
