Gas water heaters that do not need to be on a stand....
Do they now make any? Had 2 brand new ones sitting on the garage floor. Feedback please Thanks for the confusion Wayne. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I will double check my info if not answered again. |
If the burner is sealed then it can be used without a stand. Generally if they wer made after 2008 they are explosion proof.
Greg Mathias, CCHI Journeyman Carpenter Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
Water heaters should be elevated above the floor by at least 18 inches. A pilot light may ignite spilled fluid or floor-level flammable fumes if the water heater is placed at floor level.
In 2003 they started making FVIR (Flame Vapor Ignition Resistant) water heaters that do not need 18" elevation in garages. They have an enclosed front with a small viewing window.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Our county code handouts say it must be. Had 2 brand new today on the floor. Both were fvir's.. They would not have been able to install the draft pipes if they were on stands.
Patent;
An explosion proof gas-tired water heater is comprised of a housing having a water reservoir provided with a sealed combustion chamber thereunder. A flue pipe is disposed above the combustion chamber and extends through the reservoir. A gas burner and pilot are provided in the combustion chamber. At least one air supply channel is provided to supply fresh air to the combustion chamber. The air supply channel has an intake disposed a predetermined height above the floor to prevent combustible vapors from entering the combustion chamber. Vapor detectors and/or pressure sensors may be provided as added features to detect the presence of combustible vapors as well as the production of harmful carbon monoxide in the combustion chamber and to actuate the gas supply cut-off valve. Explosion Proof Gas Water Heater Flammable Vapor Ignition Resistant (FVIR) Gas Water Heaters – All 30, 40 and 50-gallon standard-vent and 40 and 50 gallon Power Vent gas water heaters are now C3 Technology™ gas water heaters. They are equipped with an advanced system designed to help prevent the accidental ignition of flammable vapors from gasoline and other sources outside the water heater. C3 Technology water heaters meet standards for “Flammable Vapor Ignition Resistance” established by ANSI, the American National Standards Institute. Learn more about the FVIR Standards. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
In 2008 FVIR's were mandated in Canada.
So now that we all know that they exist, will they be recognized when we see one, is the next question.
OK missed the new part ,but good thread to discuss.
I see them all the time. I am not a fan as they are impossable to inspect.
There are some jurisdictions that leave it up to the manufacturer. Their code will usually state something to the effect of "Ignition sources capable of igniting flammable vapors must be elevated off of the garage floor..." In which case, the FVIR water heater can be placed at floor level. Other codes will say something like "The heating element or burner chamber of appliances located in a garage must be elevated to a minimum height of 18 inches off the garage floor..." In which case, all appliances must be elevated. Most current codes allow for the FVIR water heater to be placed at floor level. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Sean has stated here in Knox county has to off the floor. I write them up also, Knew some areas do not require it . no one here has complained yet
http://www.knoxcounty.org/codes/pdfs...quirements.pdf
According to our 2006 current county code requriements they must be 18 inches off the floor. It does not specify SO I guess county codes trumps. I see fvir's all the time. What I have never seen in newer construction is them sitting of the floor. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Tankless water heater issue | sstanczyk | Plumbing Inspections | 18 | 12/2/10 6:15 PM |
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
