Inspected 57 year old home with a 17 year old water haeter. The water heater was located in a hall closet which had full louvered door leading into the hall. Also, in this room were the washer and dryer. Obviously, this set up has been in-place for 17 years. Just need some feedback on your thoughts.
| Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It's not a bed room.
Is there a mechanical vent in the closet for moisture control? If so, from that alone or with a negative pressure created by the dryer when it is working...there could be the possibility of backdrafting or flame rollout. Operate the dryer (and vent, if it has one) and do a smoke test on the water heater exhaust. Check the area around the burner for evidence of flame rollout.
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Draining a mobile home hot water heater. | Steve Evets | Plumbing Inspections | 11 | 2/20/07 11:28 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
