Old 3/30/07, 11:19 PM
Bruce A. King's Avatar
Default Gas water heater question
Does anyone know if gas water heaters have a safety cutout on the gas valve that trips at a certain water temperature?
I know electric ones have trip devices on the thermosat/contactors.
This is why the TPR valves do not see much excitement during their lifespan.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 3/30/07, 11:33 PM
Jeffrey R. Pope's Avatar
Default Re: Gas water heater question
A Watts 210 valve is a gas shut-off that operates if the heater reaches 210 degrees.
Is that what you are referring to?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/31/07, 12:15 AM
dchew dchew is offline
If you run into a Watt 210, be sure that there is a manually operated pressure release valve somewhere in the hot water line. Check the manufacturer's website for more information.
Old 3/31/07, 12:36 AM
Must be automatic, not manually operated.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/31/07, 8:58 AM
I don't see the watts type around here.
I was referring to a possible feature built into the control valve on newer units.
704 301-3207
Old 3/31/07, 2:46 PM
I stand corrected. Here is manufacturer's spec sheet.
http://www.plumbersurplus.com/pdf/01146.pdf
Solar water heating + electric water heater Todd M. Soper Plumbing Inspections 20 5/30/07 6:31 AM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
Hot water heater question carolinainspector Plumbing Inspections 9 6/19/06 1:59 PM
