Old 10/29/08, 9:44 PM
John M. Acaron's Avatar
John M. Acaron John M. Acaron is offline
Question Gas water heater TPRV discharge tube??
Do you find anything wrong with the way the TPRV discharge pipe is installed and routed? Do you find anything wrong how the Gas Water Heater is sitting on the garage? Is the distance from the garage floor to the combuation chamber of the gas w/h correct? Or does the w/h requires to be set on a stand higher that 12" from the floor?
Old 10/29/08, 9:57 PM
Jeffrey R. Pope's Avatar
Default Re: Gas water heater TPRV discharge tube??
Where's the pictures?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/29/08, 10:36 PM
You can see the pictures. I refresh and open the mesage board and there they are. Here are attached. All comments are welcome.
Thanks!
gas-water-heater-temperature-pressure-relief-valve-discharge-tube-dsc03561.jpg   gas-water-heater-temperature-pressure-relief-valve-discharge-tube-dsc03562.jpg
Old 10/30/08, 9:54 AM
mnahrgang's Avatar
Thanks!
18" in the garage is what is necessary UNLESS it is a sealed combustion chamber. According to Kenton, this is one.
As to the TPR, is the copper pipe going into the wall of the second picture coming from the TPR? If so that's wrong, it should discharge at the floor.
Mark Nahrgang
www.HeyMark.info
Old 10/30/08, 10:07 AM
As Mark says... must be sealed combustion chamber, also known as FVIR to rest on the floor.
If that's a screen in the base, it indicates that the water heater is Flamable Vapor Ignition Resistant (FVIR), which in some jurisdictions are allowed to be installed in a garage without the typically-required 18" height requirement.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/30/08, 12:16 PM
Joe Funderburk, CMI's Avatar
Originally Posted by mnahrgang View Post
...As to the TPR, is the copper pipe going into the wall of the second picture coming from the TPR? If so that's wrong, it should discharge at the floor.
Nothing wrong with it going through the wall to the exterior of the home, provided it discharges above grade and is conspicuous.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 10/30/08, 1:08 PM
mnahrgang's Avatar
Oops. my bad. Absolutely correct. Forgot about that, as I never see it around here.
Mark Nahrgang
www.HeyMark.info
Old 11/2/08, 12:29 AM
Are seismic restraints required in Florida?
Old 11/4/08, 1:57 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
It has to turn down too.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 11/21/08, 10:38 AM
John A. Sopher's Avatar
John A. Sopher John A. Sopher is offline
Shouldn't it have a downward slope?
HLC Home Inspections
Okla. Lic. #776
I am licensed Realtor with Keller Williams. Office Phone # 405-691-2708
Old 11/21/08, 9:35 PM
jhugenroth jhugenroth is offline
Please Note: jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yes, but it's hard to tell from the angle of the pic.
A.O. Smith water heater recall Gary Reecher Inspecting HVAC Systems 0 4/3/08 11:18 PM
TPR valve acox Plumbing Inspections 19 5/27/07 12:36 PM
Water Heater Dip Tube Failure jacaron Plumbing Inspections 2 2/24/07 11:28 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
