Old 5/15/07, 8:09 AM
Carl Pennick's Avatar
Carl Pennick Carl Pennick is offline
Default gas water heater vent
Is ok for a gas water air vent to terminate in the attic.
Thanks
www.wisemovehomeinspection.com
Carl Pennick
Lighthouse Point, FL
954-946 2737
407-928 8489
Florida Licensed Home Inspector #65
NACHI #04072098
ICC #5294144
Certified Master Inspector
Old 5/15/07, 8:17 AM
Joseph Hagarty,  CMI's Avatar
Default Re: gas water heater vent
No .. No
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 5/15/07, 9:31 AM
mthomas2 mthomas2 is offline
Looks to me like WH is vented via the B-Vent going through the roof (which has its own issues), and the rectangular duct is admitting in combustion air from the attic via the grills at the top and bottom of the wall behind the WH.
Old 5/15/07, 10:20 AM
Harold E. Miller's Avatar
Harold E. Miller Harold E. Miller is offline
Thanks
Attachment 11586
Attachment 11587
Joe, I believe the question was "can the combustion make up air source come from the attic?" and the question is yes. However the exhaust flue does have to discharge to the exterior.
Old 5/19/07, 11:55 PM
lfoster's Avatar
lfoster lfoster is offline
Are those broken decking boards in the second pic?
Old 5/20/07, 12:14 AM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Also, make sure those joints have screws in them to secure them.....not just tape.
Old 5/20/07, 1:06 AM
Jeffrey R. Pope's Avatar
Modern B-vents are self-locking and should not have any screws. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/20/07, 1:24 AM
that bottom connection in the second pic looked a little suspect. Just threw it out there just in case.
Old 5/20/07, 5:50 PM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Only place you should have screws is at the draft hood to flue pipe connection. There should be 3 screws installed at this connection.
Old 5/20/07, 5:54 PM
How do you guys feel about combustion air being drawn from attic with water heater located in closet and ceiling covering (sheetrock ceiling) above missing. Just hole in the ceiling above the water heater. I know the ceiling should be fireblocked, but I see this set up often in older construction.
Didnt mean to change the subject.
Old 5/20/07, 6:34 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Duct Tape or Duck Tape, is not designed to be used on Ductwork. It is general use tap. In the 2nd photo the lower section looks like General Purpose Duct Tape... The upper connection looks like the proper type of foil tape.
Off subject, what does everyone think about the use of the flex-lines used on the Hot & Cold water lines? I personally have not ever used them. I always add a 6" to 8" nipple to the top of the WH with a Di-elect union to CU. That way I have the available height for different size replacement WH. I also like to install valves on both hot & cold sides, that way I don't have to deal with waiting for the pipes to drain.
My family has owned a lot of rental homes, I worked on the construction of 90% of them.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 5/20/07, 6:52 PM
Originally Posted by jsieg
. . .what does everyone think about the use of the flex-lines used on the Hot & Cold water lines?
Standard operating proceedure in CA. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/20/07, 7:09 PM
Jeff, I had a feeling someone from CA would be the first to reply. Standard due to Earth Quakes???
Would it be normal (or a good idea) to replace them each time the WH is replaced? (Flexable things tend to crack or break without notice). I know that they are made more durable but, would you replace them when replacing a WH?
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
Old 5/20/07, 7:13 PM
tdietrich1's Avatar
Is that a dryer vent being used as a flue?
tom
Old 5/20/07, 7:55 PM
tom
Looks like flexible B vent to me.
Single wall and double wall, 1" clearance.
http://www.hartandcooley.com/vent/all_vent.htm
Larry Kage, CMI
231 929 3525
Water heater vent & corrosion to tank. dmacy Plumbing Inspections 2 1/4/07 11:01 AM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
Return air and water heater vent jorbeck Inspecting HVAC Systems 5 10/9/06 7:42 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
