Old 10/18/10, 9:30 PM
Timothy H. Barnett Timothy H. Barnett is offline
Default ghosts in the plumbing!
Ok- had a new one today...
was filling a whirlpool tub so I could check it and noticed a low pitched whistle/ howl coming from the supply pipes. I shut off the water and the noise continued and got louder for a second or two then stopped.
I couldn't get it to do it again. I checked over the pipes in the crawl space and found no issues. Any thoughts?? I've had knocks, bangs, chatter and gurgles, but this was the first whistle/ howl.
Timothy Barnett
Acclaim Home Inspections, LLC
Wadesville, IN 47638
Indiana Lic. #HI01000020
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/22/10, 5:49 PM
Default Re: ghosts in the plumbing!
Check the water pressure. If the tub has not been used in a while, there could be some pipe/faucet build-up or lime. Is there hard water in the area? Newer faucets are constructed of plastics and rubber seals, and just do not like hard water or high pressure.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 10/23/10, 8:27 AM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is offline
Our toilet just had the same issue. There was debris lodged in the bowl fill tube.
Most likely, there was debris somewhere in the supply and most likely got cleared out when you used it......probably for the first time in years!
Old 10/23/10, 12:05 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Mine: was whistling outside at the main and you could hear the whistle in the house. When I checked the pressure - 110! Recommend lower the pressure.
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 10/24/10, 8:10 PM
Joseph Hagarty,  CMI's Avatar
Check the extrol (expansion tank) on the water heater.
have encountered this before
ruptured bladder in tank
replacement corrected.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
San Antonio Air Conditioning, Plumbing and Heating Services and Repair Don Hatcheson Inspecting HVAC Systems 0 7/31/09 1:51 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
Plumbing Code changes mcyr Plumbing Inspections 0 9/8/06 5:47 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
