Old 11/9/08, 11:15 AM
Ron S. De Mott Ron S. De Mott is offline
Default glued copper fittings
Well just when you think you saw it all. On my inspection Sat. I found glued half inch copper supply lines along with the typical non primed P.V.C. drain lines. This home owner does deserve credit for at least roughing up the copper connections before glueing them. He also had the soft copper propane supply lines cemented through the foundation without protection and all galvanized fastners touching soft copper gas lines. At this point I no longer cared about all the dog mounds all over the yard.
Old 11/9/08, 12:28 PM
tdietrich1's Avatar
Default Re: glued copper fittings
There is glue for copper fittings. It's an epoxy. Are you sure you have the same stuff, photos?
tom
Old 11/9/08, 1:17 PM
Marcel Gratton's Avatar
Q: Is JUST-FOR-COPPER™ a glue or an epoxy?
A: JUST-FOR-COPPER™ is a durable polymer (a polyacrylic solid when cured) with outstanding durability and resistance.
More info at:
http://www.accentshopping.com/produc.../149558#tabtop
On The Level Inspection
Gatineau, Québec
Old 11/9/08, 2:24 PM
James F. McKee's Avatar
More info at:
this really sounds like some interesting stuff....but I've never had the nerve to try it ....does anybody have any experience with it good or bad ????.....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 11/9/08, 2:56 PM
Thanks Guys, I stand corrected it seems you can test and test till you can't see anymore and a glue or polymer as this shows up. I think I will update that report but still suggest a qualified plumber evaluate the plumbing conditions found. I knew this was gonna happen.
Old 11/10/08, 8:36 AM
Bob Elliott's Avatar
I say, sign of non-professional work.
Old 11/12/08, 1:28 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
I have to agree Robert.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Tinned copper & Copper mnahrgang Electrical Inspections 2 3/13/08 6:21 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 11:50 AM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 11:22 AM
