I have not seen clear solder before?
Looks like epoxy cement
They use it to glue golf clubs too Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks like flux,a flowing agent brushed on before soldering is done.
Did it feel soft and greasy? From the photo it looks like the soldering was not done. Was this a new constuction Inspection or a new water heater install?Was the water on? If it's left unsoldered it WILL leak and worse blow apart. I would go back and check again. |
"Similar in appearance to epoxy adhesive intended for this use":
http://superglue.supergluecorp.com/copperbond.html http://supergluepds.com/pdsdocs.aspx?partno=80582 Of course, you can't determine this for certain, that (unless you check) it's acceptable to the local AHJ, or that that it was installed "per manufacturer's instructions" ... Last edited by mthomas2; 6/28/07 at 8:47 AM.. |
It was not flux guys.
Copper glue, well I'll be. Thank you Michael |
| Replacing Subfloor | Jim B. Zink | Interior Inspections | 31 | 7/7/07 11:33 PM |
