Had not found a leaking shower pan in about two months and was starting to think I had them all found
I have increased my business two fold by using the IR camera on shower stalls and electrical panels Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Nice catch.
Have you increased your rate since using the camera? Serious question and not trying to pry but I am thinking about this service. Not so much an attempt to increase the number of inspections I provide but to increase my rate. Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
Just curious but how do you know you are not just calling out a wet carpet?
It would get wet and hold moisture from plain old normal use. Yikes ,carpet in a bathroom is so dumb by the way. |
It don't look that way when it is just a wet carpet.
Can you see the evaporative effect and where it comes from? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Yes Vince I have increased my price by $100.00 per inspection since I started IR. I am not bragging but I have clients seek me out because of my IR. I was the first in Oklahoma to incorporate IR into a inspection and I have perfected on my own a way of inspecting shower pans and electric panels and it has paid me a premium in the amount I charge and the amount of inspections I do.
Bob Very easy If one has had IR training at all. But in this case it was super easy because the house had been vacant for months. As for carpet in the bathroom being dumb you would have to speak to the owner about that I just inspect them. As for inspecting shower pans I much prefer ceramics it blows the clients mind when I find water below the ceramics then I get to inspect all of the clients friends and all of the relatives that is how it works Bob.
Very nice Charley. Do you inspect only the shower stalls and electric panels for the extra fee? Do you check around windows, doors, roofs, exterior walls, finished basement walls. Do you look and report on areas of heat loss also? Also, where did you receive your training?
774 Manor Road Staten Island, NY 10314 718-514-3393 |
I received my IR training from FLIR ITC and I am a big believer in the proper training not only in IR but any field Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Basic inspection protocol I'd imagine... ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
How I inspect a shower with out a camera is with a moisture meter. The moisture will increase after the shower runs for a while. About any shower over 10 years old leaks some.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
It can be tricky as the floor gets wet at the sides just from going through those rubber gaskets at the bottom of the shower doors.
I don't agree with that statement must have very poor contractors in your area. The ones I find here are from the 70's and early 80's the one in my pic was 1978 and appear in good condition from the interior, grout in the tile gave no visual appearance of being bad
That is why one must pay attention and control the test I turn the shower head so it does not even spray toward the door and I don't open the door after I start the test until after I take my images as water might drip from the bottom of the door gasket
Like to hear more specifics ,always. |
