Does anyone know if this gray pipe is okay for use with a TPR? I don't want to call it out, if it is.
| Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Mark,
Without being able to see any markings, I would call it as being PVC (which I believe gray pipe is), which is not approved. I'm not sure if there is a gray CPVC pipe. Is the relief/test handle too close to the wall/trim to operate? If so, I would call it out for that (unable to operate). Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Thanks Jeff, That's what I was thinking.
Schedule 80 CPVC is grey. Then again, so is electrical conduit, but that's PVC.
The plumbers and municipal inspectors have no problem with it here in my neck of the woods. I almost always find it in manufactured homes.
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Is this allowed? | belliott | Plumbing Inspections | 4 | 7/15/09 6:40 PM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
