Old 2/7/06, 6:18 PM
David White David White is offline
Please Note: David White is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Grease Trap / Drum Trap
Hi I'm taking a Home Inspection class and we are puzzled about the difference between a Drum Trap and a Grease Trap:
Can someone enlighten us please. A pic or diagram would be great too.
Thanks
David White
Old 2/7/06, 6:41 PM
David P. Valley's Avatar
Default Re: Grease Trap / Drum Trap
David,
Welcome to NACHI.
A drum trap is a plumbing fixture, (which is cylindrical in shape), which retains water as a seal, with an outlet at its top and an inlet at its base. Used in plumbing fixtures that are too low to the floor for installation of a P-trap.
Attachment 1110"click for bigger pic"
A grease trap or interceptor is a passive device required by municipalities to stop grease, fat, oil, wax or debris from entering the city's sanitary sewer system. Such materials cause blockages in the system, which cause backups and overflows. Traps and interceptors are designed to separate greasy materials from wastewater so that they can be removed before they enter the sewer system. These are found mostly in Restaurants or very busy cooking areas.
Attachment 1111"click for bigger pic"
Trap help dbucknavich Plumbing Inspections 29 8/8/07 9:48 PM
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 1:17 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
