Old 8/4/11, 10:41 AM
Bryce W. Jeffrey Bryce W. Jeffrey is offline
Default Green copper supplies
This is a 15 year old semi-detached with copper supply lines. This photo was taken in the main floor bathroom adjacent to the party wall. There is no indication of discoloured copper anywhere else in the house. Comments sure will be appreciated.
B.
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/4/11, 10:59 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Default Re: Green copper supplies
Chemical reaction to sulfur, oxidation or some form of high moisture source.
Judging from the rust under the basin high moisture would be my guess.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/4/11, 11:19 AM
Thanks Kevin but moisture does not seem to be the problem. Home was in excellent condition and well maintained. My thoughts were a chemical reaction to some product stored in the vanity? The colouring is perfectly even and no evidence of the same anywhere in the house.
Old 8/4/11, 11:42 AM
KEVIN WOOD's Avatar
Did you do a moisture reading near the penetration of the wall. There is too much rust on that basin.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/4/11, 11:43 AM
Did that but I am leaning towards chemical reaction
Old 8/4/11, 4:43 PM
Charley L. Bottger's Avatar
Appears to be a chlorine base chemical to me being in a refinery for many years seen that reaction to copper most every day
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/4/11, 4:51 PM
Bryce, you seem intent on ignoring the presence of moisture. Why?
It's a sink--water runs in the sink and sometimes leaks slowly--so slowly that it doesn't puddle, but its presence will still be known by the rust.
Some domestic water suppliers add chlorine in the water. If there is a small leak, over time the combination of all the factors involved could lead to green copper.
Old 8/4/11, 6:17 PM
David A. Andersen's Avatar
Stuff stored under the sink..
BPI# 5015804
Old 8/4/11, 7:15 PM
KEVIN WOOD's Avatar
Stuff stored under the sink will not cause that much rust on the basin.
There can be a stack effect at the vent stack area of the wall that is pulling moisture into the cabinet. This can be tested with a smoke pencil.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/4/11, 11:19 PM
Lawrence W. Losciale's Avatar
Lawrence W. Losciale Lawrence W. Losciale is offline
I'd say the chlorine or some other strong oxidizer. I've worked with pools for over 30 years, retail, construction, service and repairs. Chlorine fumes could edfinately do that (including the rust on the sink). Perhaps the used those 1000 flushes tabs, they're just chlorine, and stored them under the sink.
Old 8/5/11, 3:30 AM
KEVIN WOOD's Avatar
Good point Lawrence!
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/5/11, 8:29 AM
Thanks for all the input. Jae, I was not ignoring any posssibilities. The house was absolutely immaculate. No moisture or leaking was evident and the green patina was very evenly distributed over the supplies. It appeared to be a vapour issue and or chemical reaction of some sort. The chlorine issue seems appropriate in light of the overall condition of the home and I lean to the storage suggestion. Thanks to Lawrence and Charley.
Again thanks to all who contributed.
Old 8/5/11, 8:54 PM
Don't f u c k with me this week, your a simple *** if you stand behind that!
Give me some damn facts that it will not.
I have scars on my face from oxidents in a pool room.
Go back to Nick School dumb ***.
It can kill your sorry ***, but not turn copper green!?
Yea, right!
BPI# 5015804
Old 8/5/11, 9:09 PM
Calm down Dave. We're talking from experiance, he obviously is not.
Old 8/5/11, 9:24 PM
Chuck Evans's Avatar
You're wrong. It most certainly can.
Chlorine will cause far more oxidation than water. Also, I have never seen moisture cause that perfect green patina evenly around all surfaces of the copper tubing (water will leave drip marks as it runs down the pipe). Chlorine gas, on the other hand, will envelop the tubing evenly from top to bottom.
This was caused by stored chemicals, almost surely chlorine.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Light Switch Near Shower vsantos Electrical Inspections 204 3/19/12 9:58 AM
Total galvanic reaction? jtribuzio Plumbing Inspections 19 4/3/10 2:18 AM
Green corrosion on copper waste pipe rbrady Plumbing Inspections 2 8/27/09 9:58 AM
green crystallized matter on copper pipe Scott Schultz Plumbing Inspections 5 10/17/07 3:30 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 11:22 AM
