Old 10/16/07, 10:13 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default green crystallized matter on copper pipe
What would cause one side of a soft water loop to have a thick amount of green crystallized matter on the copper pipe? I could not see if there was a dissimliar metal attached to the copper that would have cause this or would a leak have caused this buildup? thanks.
Old 10/16/07, 10:33 PM
William Warner's Avatar
William Warner William Warner is offline
Default Re: green crystallized matter on copper pipe
Active leak and corrosion.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 10/17/07, 4:24 AM
It's called verdigris, not to be confused with ambergris.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/17/07, 6:22 AM
David P. Valley's Avatar
If it's crusted up like the picture William is showing, it's seepage from a leak.
If it's only a light coat of this substance, it's usually caused from flux build-up that the plumber never cleaned off after soldering the connections (some Plumbers are actually lazy). They're suppose to clean the soldered area with steel wool once they're completed with soldering.
Old 10/17/07, 9:19 AM
Banned
Attachment 15258
Acidic water is needed to cause that much corrosion in connection with the slow leak.
Old 10/17/07, 3:30 PM
Patinated=
One example of a patina is a green surface texture created by slow chemical alteration of copper, producing a basic carbonate. It can form on pure copper objects as well as alloys which contain copper, such as bronze or brass.
Exposure to chlorides leads to green
patina
pa·ti·na
1 a: a usually green film formed naturally on copper and bronze by long exposure or artificially (as by acids) and often valued aesthetically for its color
Similar to a copper roof turning green after 7-10 years of acid rain on it.
JMO
Marcel
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Ground to copper pipe? crichiii Electrical Inspections 11 10/25/08 12:39 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 11:22 AM
