Old 3/18/08, 11:27 AM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Grind pump
Any one have any ideas? My grind pump in the basement will not shut off. Float moves good.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 3/18/08, 2:29 PM
David P. Valley's Avatar
Default Re: Grind pump
Did you try unplugging it and powering it up again?
Old 3/18/08, 2:33 PM
If that don't work, it may be an air lock, maybe some debris under the float assembly, or a defective switch.
Old 3/18/08, 3:22 PM
iniquette's Avatar
Took it out and cleaned it up. I think it was just a bit dirty. Working now. thanks David.
Ian Niquette
Markesan WI 53946
Active Rain Network
Gasoline at $4 Coming to a Pump Near You jburkeson1 Miscellaneous Discussion for Inspectors 1 4/24/07 7:00 AM
Sump Pump Recall jbushart Plumbing Inspections 1 2/15/07 10:50 AM
Sump pump.. legal installation? Steve Meyer Plumbing Inspections 7 12/17/06 8:34 AM
Sump pump question dmacy Plumbing Inspections 5 5/11/06 2:28 AM
