Old 2/7/10, 6:01 PM
Mark Thiltgen Mark Thiltgen is offline
Default grinder pumps
Had a grinder pump in house the other day which went to a community septic system. Anyone have information on them? Just curious and want to know more about them. Mark T
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/7/10, 6:23 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default Re: grinder pumps
http://www.wssc.dst.md.us/INFO/grinderpumpqa.cfm
Link/info provided by Mr. Google. He's a great friend to have, and friends need to be visited once in a while, otherwise the companionship is lost.
Old 2/7/10, 7:57 PM
My third grade teacher simply said, "Look it up!"
Old 2/8/10, 7:17 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
If it was a grind pump, that normally means the pit has a drain coming into it from a toilet somewhere, right? So, the septic would be the best spot for this to drain to. I have one in my home. Most of these have a relatively short life span on them of less than 10 years. I recommend installing a high water alarm on them, because unlike when your sump overflows and you get ground water overflow and a pain in the azz, this is gonna stink and make a big mess.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/9/10, 12:49 AM
Nick Gromicko's Avatar
http://www.nachi.org/septic-course.htm
Find a Home Inspector
Old 2/12/10, 3:16 PM
Grinder Pumps
Old 2/12/10, 5:30 PM
Bob Elliott's Avatar
Is this the same thing as ejector pumps like I wrote a blog on Active Rain.?
http://activerain.com/blogsview/2665...kles-in-water-
Great site for understanding heat pumps sstanczyk Inspecting HVAC Systems 2 8/3/09 11:58 AM
CPSC Recall- A.O Smith Recalls Water Pumps pabernathy Plumbing Inspections 0 6/24/08 8:11 PM
well water pumps and so forth info wanted psiposs General Inspection Discussion 3 8/27/06 2:49 PM
Heat pumps in Florida cobarr Inspecting HVAC Systems 7 4/17/06 11:58 AM
