Old 2/12/10, 2:18 PM
Nick Gromicko's Avatar
Default Grinder Pumps. Please proof this new inspection article.
Grinder Pumps
Find a Home Inspector
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/12/10, 4:12 PM
Bob Elliott's Avatar
Default Re: Grinder Pumps. Please proof this new inspection article.
Why is this not called Ejector pump?
You may wish to mention it by that name also if it is the same thing.
I never hear the term Grinder pump
Old 2/15/10, 2:54 PM
Rob London Rob London is offline
good point
Researcher and Technical Writer, InterNACHI
Old 2/15/10, 3:34 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
good article Rob. Must be a regional term Bob, I hear them referred to as grinder pumps in my area mostly.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/15/10, 3:40 PM
Never in Chicago so should be a duel term.
As you said regional.
I did a article at AR on Ejector Pumps,that does not even reference the term Grinder
Old 2/15/10, 4:14 PM
Good point Bob, but there seems to be a difference in their makings.
Hydromatic Sewage Ejector Pumps
According to the recommended standards published by SSPMA (the sump and sewage pump manufacturers association); A sewage pump is powered by an electric motor for the removal of wastewater from a sealed basin containing solids of up to 2" diameter.
Grinder Pumps shred solids and raise sewage to a higher elevation through pressure sewers. They shred sewage discharge into a finely ground slurry that can be sent through a small-diameter pressure pipe. Grinder pumps are connected to septic pipes and transport waste from households and businesses to sewage treatment systems. Unlike a well pump, grinder pumps are fitted with special cutting ring systems that are mounted to the pumps motor shaft.Grinder pumps are often installed on municipal sewage holding tanks.
Old 2/15/10, 4:32 PM
Hi Marcel
If you put in a bathroom and toilet in the basement it is a Ejector Pump in these parts.
Here is a link to my personal experience with a not functioning Ejector Pump.
http://activerain.com/blogsview/2665...kles-in-water-
Old 2/15/10, 4:47 PM
iniquette's Avatar
Originally Posted by belliott View Post
Hi Marcel
I agree with you Bob, just saying generic terms get used alot.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/15/10, 5:04 PM
I agree with you Bob, that is what they call it here too.
Just made that post to show that they have different meanings and they are different animals.
And a Grinder Pump System
Hope this clarifies it.
Old 2/15/10, 5:07 PM
Thanks Marcel
Now back to my Back flow Valve research.
Old 2/15/10, 5:11 PM
iniquette's Avatar
You are right Marcel. They are different animals, but the average Joe gets confused sometimes.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/15/10, 5:20 PM
James F. McKee's Avatar
sounds like a lot of sht...to me.....sorry i just had to....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 2/15/10, 5:24 PM
Yep and the big sh$tters need the grinders.
Old 2/15/10, 5:31 PM
I believe that sums it up nicely Sir.....
Jim Mckee
Amherst, Ohio
grinder pumps mthiltgen Plumbing Inspections 6 2/12/10 4:30 PM
New article on sump pumps inxil InterNACHI & RealMatcher Blogs 0 5/28/09 4:00 PM
Please proof this new article on Sump Pumps. gromicko Miscellaneous Discussion for Inspectors 13 5/12/09 11:04 PM
Roy the proof you asked for wdevries Canadian Inspectors 55 7/8/08 10:30 AM
Are electricians supposed to use these tools as per 70E? jtedesco1 Electrical Inspections 27 12/15/07 3:40 PM
