took the pic from the side and should have taken it from the front.
Is handle forward supposed to be hot since it would be on left side and handle pushed away the cold side? No h/c designation of any kind on this Moen. Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
pic did not load
I have found them both ways and asked a couple of plumbers this question. I get different answers. I don't call them up either way as they are not marked. I think when you pull it towards you it should be hot as that would be left if facing the lever.
Greg Mathias, CCHI Journeyman Carpenter Level I Thermographer Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
Good question, so I had a look at mine.
This faucet manufacturer indicates forward should be hot at the tub but the opposite at the sink... I guess it doesn't matter. Marcel Gratton, NACHI04011210, CMI, NHI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ Last edited by mgratton; 12/6/12 at 3:59 PM.. |
My Price Phister back is hot forward is cold
Gerald L. Coy, P.E. Rochester Home Inspections & Engineering, PLLC http://rochester-home-inspections.com Serving Rochester, NY and its metropolitan area. |
According to Moen, forward is cold.
Their faucets are manufactured with a label on the hot water line for identification. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
I have always found them as hot is back and you cool the water as you pull the handle toward you.
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Council Bluffs Home Inspector Iowa Home Inspector Council Bluffs - Facebook Active Rain Member |
I agree with the other posts, cold is towards you and hot is to the back.
Watch us fill out an entire electrical section in less than 60 seconds!
$50 off for InterNACHI members. Discount code: FORNACHI Toll Free: 888-545-4096 Email: support@ezhomeinspectionsoftware.com We also offer affordable home inspection websites EZ Home Inspection Software |
| Hot Neutral Reversed Recommendations | pbreen | General Inspection Discussion | 6 | 4/8/11 10:09 PM |
| reverse polarity?? | Scott Schultz | Electrical Inspections | 33 | 10/24/07 1:50 PM |
| Water Heater supply and return reversed | dosborne | Plumbing Inspections | 3 | 8/5/07 2:08 PM |
| Recall of Polarity Reversed Outlets | Nalliah Thayabharan | Electrical Inspections | 3 | 4/20/07 10:50 PM |
