Old 8/20/08, 3:48 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default H20 heater in utility room
Can someone please refresh me? In a utility room, this is a 1982 build, with a 2008 water heater, isn't a pan needed with a 1" pipe running to the exterior?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 8/20/08, 3:54 PM
Michael Larson's Avatar
Default Re: H20 heater in utility room
Is there a floor drain?
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 8/20/08, 4:03 PM
Jeffrey R. Pope's Avatar
The key being a "utility" room, generally speaking, in most cases the answer is no.
There are exceptions of course. If the utility room is above a living space it would be required. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/20/08, 4:33 PM
No sir.
Excellent. thanks.
Old 8/20/08, 4:36 PM
mnahrgang's Avatar
I like these... http://www.getfloodstop.com/?Click=35
Mark Nahrgang
www.HeyMark.info
Old 8/20/08, 4:41 PM
Let the manufacture's installation diagram help you.
It looks to be a ceramic floor so unless there was a serious problem there would be no damage to the structure.
Michael Larson
Hudson, WI
InspectraPro
and
Furnace/water heater room door sspradling Inspecting HVAC Systems 10 1/15/08 1:06 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
Exhaust fan in room with gas water heater and furnace jweinberg Inspecting HVAC Systems 7 2/18/06 2:23 PM
