Old 8/25/07, 12:15 AM
Tom Yeager Tom Yeager is offline
Default H2O Heater automatic pump..??!!
Anybody know what these are? Gas water heater is installed in the basement. There is a timer pump on the drain valve that goes up and follows the floor joists into finished space. The only thing on the exterior of the house is this weird SMALL piece of copper tubing. Thoughts, comments, experiences?
ID:	14137   h2o-heater-automatic-pump-p8240042-2-.jpg.JPG
Tom Yeager
Owner/Certified Inspector
Inspect-It 1st
303-464-9090
www.tyeagerinspects.com
NEHA Radon Certification # 104169 RT
NACHI Certified Home Inspector
Old 8/25/07, 12:36 AM
Jeffrey R. Pope's Avatar
Default Re: H2O Heater automatic pump..??!!
That's a "loop" (aka recirculating pump).
I don't know what the exterior piping is.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/25/07, 12:54 AM
Banned
Looks like tubing for propane. Any chance this house had a propane DHW tank before it had natgas?
Old 8/25/07, 1:28 AM
I doubt it had propane. Built in 2001 and not real common in these residential neighborhoods around here (Longmont, CO.)
Tom Yeager
Inspect-It 1st
303-464-9090
Old 8/25/07, 6:33 AM
Russel Ray's Avatar
The second picture looks like exterior gas and water plumbing for an outdoor grill and refrigerator/ice maker.
Old 8/25/07, 9:09 AM
Michael Larson's Avatar
Never mind. On second look, I didn't see what I thought I saw.
Old 8/25/07, 9:23 AM
David P. Valley's Avatar
That circulating hot water may be used as a radiant heat.
Could that 1/4" piping be some sort of drainage pipe?
Old 8/25/07, 10:58 AM
Banned
It may be but if it's on a timer, one would think it would be for domestic use so as to provide instant hot water in the mornings or from preset periods when hot water demand is higher. To have it shut down, say overnight, is an energy conservation feature.
I'm involved in a litigation in a supposedly highly efficient all-electric house (with HP/AC) where the costs are much higher than projected. It has a 60 Imperial gallon electric hot water with 24 hour recirculation. Poor pipe insulation and the continuous heat loss is putting bills up:
(1) the straight cost of electric resistance `supplied heat loss from the pipes takes away from the running time of the heat pump at approximately 50% heat savings. There could be 2000-3000+ watts of pipe heat loss all day that prevents the HP running at its most effiecient levels during the mild shoulder seasons when COP's of 3-5 are attainable!! This may be enough to keep this well insulated airtight house comfortable.
(2) in the summer, this is an added internal heat gain that causes the AC to run longer.
Both of these items are costing the homeowner!!!
Old 8/25/07, 10:41 PM
Here's another opinion....
In some areas hard water causes build-up int he bottom of a heater resulting inpremature failure. Givne that there is a timer involved, I'd guess it is a blow-down system that automatically bleeds a small amount of flush water out of the heater on a timed schedule.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 8/26/07, 12:52 PM
I don't subscribe to the "efficiency theory" of adding a timer to an electric water heater.
The timer may keep the heater from coming on in the middle of the night, when there is no hot water demand, but this also allows for the tank to cool overnight. The heater then has to work longer in the morning to bring the tank back up to temp.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Client wants a new water heater adirienzo General Inspection Discussion 47 7/14/10 3:03 PM
Gasoline at $4 Coming to a Pump Near You jburkeson1 Miscellaneous Discussion for Inspectors 1 4/24/07 7:00 AM
Pentair Water Pool Gas Heater Recall Gary Reecher Inspecting HVAC Systems 0 1/4/07 9:15 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
