![]() ![]() ![]() Thermal-actuated damper... Right? I don't like these. I always see signs of venting problems on appliances with these dampers. Defect! |
Did you get a good photo of the label?
tom |
Why wouldn't you simply call for removal, a simple fix? John Kogel www.allsafehome.ca |
It looks like it has been in there a millenia or two, I'd just call to have it repair/replace.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Heater Ben?.....nope, I never seen one, all we have is cool air conditioning-- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
No I have not seen one of those in my area either they would typically be a bad idea. What did you see other than the damper that made you call for further evaluation or were you just cya. Personally I have to have a reason for further evaluation and state it in the report as not performing its intended function.
They cause over heating of the heat exchanger on furnace start up ,they open very slow and you will have fumes roll out. I recomend removal.
