Is the yellow wrapping for preventing or thawing out frozen pipes??
Is the device under the first floor laundry sink a pump? Thanks |
Yes the yellow heat tape is to prevent freezing and the little device under the sink sure looks to be a pump with a timer for what reason I have no clue.
The first pic is improperly installed heat tracing.
Rodney Misener, CMI Trinity Inspection Services Pictou County, Nova Scotia http://www.trinityinspectionservices.com Certified Master Inspector Certified Level 1 Thermographer Certified Energy Advisor WETT eCertified Inspector IAC2 Radon/Mold Certified Infrared Certified |
That's correct. Heat tape is not supposed to cross over itself according to the mfgs. instructions.
The second pic is a hot water recirc pump with a built in timer. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
In addition, the heat tape will not be fully effective unless the system is insulated. Also, for best efficiency, a thermostat should be installed so that the heat tape is only on when needed.
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 10:47 PM |
| Carrier heat pump fires? | lprinzi | Inspecting HVAC Systems | 3 | 10/12/06 7:31 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 12:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 9:17 PM |
