Old 9/18/06, 8:32 PM
brepanshek brepanshek is offline
Please Note: brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Heat tapes
Any comments on finding heat tapes on pvc water lines? I inspected a modular home that was on blocks and skirting around base of home to stop drafting underneath home, water line to outdoor hose bib was wrapped with a heat tape and then pipe insulation over that. It was then plugged into an extention cord that ran about 20' to and exterior outlet. I once heard heat tapes are not good for pvc pipes. Give me your thoughts, sorry no pics didn't have camera with me.
Old 9/18/06, 9:10 PM
Jeffrey R. Pope's Avatar
Default Re: Heat tapes
I have no idea what you're talking about. "A waterline from a hose bib plugged into a receptacle?"
That doesn't sit right, regardless of what kind of tape is used.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/18/06, 9:16 PM
Michael Larson's Avatar
Jeff, have you lived where it gets very cold?
This is not uncommon under a mobile home even with skirting though I'm not sure about the heat tape being used on pvc pipe. The heat tape mfg. application guide should be consulted.
Old 9/18/06, 9:19 PM
No I haven't (55 is cold to me). Can you explain to me what he's referring to?
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/18/06, 9:21 PM
Oh, heat tapes, now I've got it.
I was thinking tape. Like foil tape
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/18/06, 9:25 PM
Sure. It really does get as cold as -30 F here. It's brutal.
More info here: http://www.mygreathome.com/fix-it_guide/heat_tape.htm
Michael Larson
Hudson, WI
[/I]
Old 9/18/06, 9:28 PM
Got it Mike, thanks. It just took me a minute to. . uh. . warm up
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/18/06, 9:31 PM
cfuoco's Avatar
cfuoco cfuoco is offline
Please Note: cfuoco is a non-member guest and is in no way affiliated with InterNACHI or its members.
http://www.heatersrus.com/pipe.htm
http://www.cpsc.gov/cpscpub/pubs/5045.html
What I found for you after a very quick search.
Old 9/18/06, 9:33 PM
I suppose we could arrange to wrap in heat tape and plug you in for faster warmups
Old 9/19/06, 8:46 AM
Thanks guys for all your help, great links, I copied them and will use them on my reports and to make aware of this to my clients. Thanks again, I am always learning something new here on the message board.
Old 9/24/06, 7:51 PM
So... from the link to My Great Home the answer to the original question is...
"If your water supply piping is plastic, ONLY use automatic thermostatically controlled heat tape. Non-automatic heat tapes can damage plastic pipes, especially if the taped pipes are covered with insulation.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
efficiency of 15 yr old peerless afrost Inspecting HVAC Systems 11 11/19/07 9:51 AM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 10:47 PM
Radiant Heat Transfer rmyers1 Structural Inspections 0 5/31/06 11:21 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 12:15 AM
