Old 8/6/09, 2:05 AM
Richard Mangold's Avatar
Richard Mangold Richard Mangold is offline
Default heater hot & cold shutoffs
Are there issues if a hot water heater has both a hot and cold shut off rather than just cold?
Rich Mangold
RCM Home Inspections, LLC
www.RCMHomeInspections.com
Email: Rich@RCMHomeInspections.com
Phone: 847-698-5993
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 8/6/09, 2:21 AM
Chuck Evans's Avatar
Default Re: heater hot & cold shutoffs
Nope
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 8/6/09, 6:25 AM
David P. Valley's Avatar
If the hot side is shut off, they'll eventually find out.
Old 9/15/09, 10:34 PM
Scott C. LeMarr Scott C. LeMarr is offline
Default Re: Water heater cold shutoff distance
I found in the code check book that a valve is required on cold water supply at or near the water heater (UPC 605.2). Anybody know how near is "near" and can the valve control other plumbing? This water heater has a valve over 6' away from it and also controls the cold to the basment shower.
Scott C. LeMarr
Honest Home Inspections, LLC
Master Indoor Environmental Specialist (MIES)
Certified Mold Inspector & Assessor
Certified Weatherization Inspector for WI
262-424-5587
www.HonestHomeInspections.com
www.MilwaukeeMoldInspector.com
Old 9/16/09, 6:29 AM
Scott,
You can recommend an individual shut-off for the shower, but other than that, I don't see a problem with that set-up.
Old 9/16/09, 12:06 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Saw somewhere that it's not allowed in Chicago, but no problem in the rest of Illinois.
Other threads...
http://www.nachi.org/forum/f2/valves...heaters-43260/
http://www.nachi.org/forum/f2/hot-wa...ce-more-43266/
http://www.nachi.org/forum/f22/shut-...-heater-35499/
*added...
LOL, just realized I was a bit late to the dance.
8/6/09, 1:05 AM
Cold water from an indirect water heater? kshepard Inspecting HVAC Systems 3 8/17/07 5:22 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
Hot water heater Hot and Cold hookup phughes Plumbing Inspections 20 5/11/06 1:04 AM
small valve on cold water supply ahead of water heater? Walt Hoffman Plumbing Inspections 6 1/23/06 7:44 AM
