Old 10/14/10, 11:07 PM
John Safstrom John Safstrom is offline
Default Height of element in electric water heater? (TX)
I haven't been seeing many electric water heaters, but had one yesterday mounted on the 18" stand in the garage. I had to go back to the Texas SOP and see if it was required to be above the garage floor or not.
SOP states that the burner/element must be 18" above the floor. So if the element is high enough in the electric water heater design, then it could sit on the empty garage floor in a pan and not be a deficiency?
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/15/10, 1:32 AM
Chuck Evans's Avatar
Default Re: Height of element in electric water heater? (TX)
Correct.
The lowest point of ignition must be 18 inches above the floor. If the lowest electrical component is the lower element (usually it is), then the element must be 18 inches above the floor.
There has been much lively debate on this topic in other threads. However, as you have already discovered for Texas inspectors, it is clearly defined in the SOP.
Don't let any non-TX inspector lead you astray of your SOP requirements.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 10/15/10, 8:04 AM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
Sounds like you have interpreted it correctly. Great advice from Chuck too
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Old 10/15/10, 9:27 AM
Thanks for the replies. I'm sure all electric WH's are different, but in general how high up in the tank is the lowest element. Just want to get an idea if I find one on a 10" or 12" platform.
Old 10/15/10, 11:25 AM
My advice is to just go by the height of the bottom of the lower element cover.
Houston, TX
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Water Heater Height Requirement Skip Erwin Plumbing Inspections 7 9/7/07 8:34 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
