Old 5/31/06, 10:15 PM
cvowell cvowell is offline
Please Note: cvowell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Help with correct term?
Can someone help me with the correct name for this 'pipe', connector,,, ?
I need to identify it correctly for a report.
Thanks.
Old 5/31/06, 10:23 PM
Default Re: Help with correct term?
Aside from "wrong"?
"Flexible drop pipe" may work.
Old 5/31/06, 10:24 PM
Jeffrey R. Pope's Avatar
POS or flex connector.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/31/06, 10:25 PM
...or corrugated flexible drop pipe.
Old 5/31/06, 10:30 PM
AAHHH Flex Connector. of course.
Yeah, I got the 'wrong' part.. 3 times over. All the sinks were like this beauty.
You should have seen the the nice electrical handy man special in the attic.
Nothing better than a POS house with no working AC, in a crappy neighborhood when its 105 deg's outside.
Thanks Jeff and Larry. I appreciate the help!
Old 6/1/06, 12:01 AM
hspinnler's Avatar
hspinnler hspinnler is offline
Please Note: hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
What's worse, a POS house in the 93 degree extra humid heat in the Southeast or a POS house in 105 degree heat with no humidity? Should have made a poll for that.
Old 6/1/06, 12:44 AM
Brian E. Kelly's Avatar
I call those Dr. Suess plumbing connectors Cheryl.
Old 6/1/06, 12:45 AM
tneumann's Avatar
tneumann tneumann is offline
s(l)inky
Old 6/1/06, 1:11 PM
tnoisaw tnoisaw is offline
Please Note: tnoisaw is a non-member guest and is in no way affiliated with InterNACHI or its members.
Well normally I would would use a slip tube and as you all pointed out would not use this unless you wanted to call me back to clean your drains.
FYI- the term flex connector is often used on supply tubes for water going from the shut off to the faucet or dishwasher such as what you will find at the link provided. You may call this a corrugated slip tube I suppose.
http://www.plumbingsupply.com/flexes.html
This term is also used for gas connectors.
Old 6/1/06, 1:32 PM
They call them things Accordian Drains 'round here.
Old 6/1/06, 3:16 PM
Me, too...
Old 6/1/06, 4:15 PM
jthalmann jthalmann is offline
Originally Posted by tneumann
s(l)inky
near correct condensate drain bking Inspecting HVAC Systems 2 9/19/07 2:51 PM
Correct connect at Furnace tmartens Plumbing Inspections 2 5/1/07 10:33 PM
First to answer this question substantially correct wins a NACHI Beam. $109 value. gromicko Miscellaneous Discussion for Inspectors 28 1/30/07 5:30 PM
Is this correct cpennick Electrical Inspections 4 6/15/06 11:15 PM
