I have a past client that needs someone to find his well point. He has a well pump in the basement but needs to find the origin in order to map out it’s distance from the septic. Who is the person to call in this situation? He said he talked to a well driller but he was no help. Any ideas?
That is very common there, but be real careful about points up there. I had a well company fail a point up there just because they fail so often in that soil type. From what I understand another well company told them the same thing. I have failed one or two points there myself. Mostly near the Ballston Spa/Malta side of things
Most of the time I will find the well location on the “as built” diagram. Luckily my main county has all their records online for easy download. That should give you the measurements as well as location. Good luck.
Here’s one I had the other day that was through the slab.
Most driven points are less than twenty feet deep and usually less than 75 feet from the home. I typically see them 20-25 feet due to the shallow well pump.
When the well head is buried I recommend someone find it with a metal detector. Most of the time these wells test positive for coliform bacteria.
Another problem with these wells is supply, this time of year when the seasonal high water table is low they can stop producing. I had one next to a lake and when they drained the lake down for the winter it went dry, that’s when the owner knew it was time to close up and head to Florida
It’s a little “out of the box”, but I’ve seen it work several times. I wouldn’t believe it had I not seen it.
Find an old timer who can use a “water witch”. Sometimes it’s two branches, I believe from a weeping willow tree, or two metal rods. I worked for a well driller for a while, and he used the water witch. Wells were 2 to 3 hundred feet deep, and he always hit water where he said he would.
