Need help with an age from this serial number off an electric AO Smith H/W heater. Searched high and Low, No dough...
ELJF40K202172000 Thanks in advance! John Buckley 20/20 Home Inspection of NJ 1-888-798-5190 JOHN@THE2020HOMEINSPECTOR.COM WWW.THE2020HOMEINSPECTOR.COM WWW.NJMOLDTEST.COM |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Are you sure that's not the model number. AO Smith usually has 10-11 numbers and letters in the ser #. I've not seen that many before
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI Last edited by dokeefe; 3/25/11 at 10:12 PM.. |
For future reference you can check the TPV date code. These usually have not been changed and should give some clue as to the age of the water heater.
Watts brand TPV's are popular....the 1st 2 digits of the date code is the year of manufacture. For example: 91011 (found on metal tag). As David mentioned, it appears as if you listed the model #. Was the heater 40 gal. capacity? Some examples of A.O Smith serial #'s: MG96-0884240-230 0291XXXXXXXXXXX 790-K-74-40767 Scott Coslett National Property Inspections Berwick, PA www.PennInspector.com scoslett@pa.metrocast.net "Life is Tough. Its even tougher if you're stupid" John Wayne |
I Think you right, time to change the batteries in the flashlight...
| Tankless water heater issue | sstanczyk | Plumbing Inspections | 18 | 12/2/10 6:15 PM |
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
