Well?
Some expensive dishwashers have the high loop built in. I always mention that in the report so that they have to research it.
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Even the expensive ones (Bosch and Asko anyway) that have a built-in air gap still require and external air gap----countertop or Johnson-T.
I believe the high loop or air gap are required so if something gets clogged the homeowner will see the water in the bottom of the sink and investigate.
The "built-in" high loops are typically on the supply side of the dish washing machines, not the drain/waste side.
The method in your picture Brian, is an improper installation - period. Any connection that allows the potential for waste from the disposal to enter the drain line is improper (the drainline must slope downhill to the disposal connection) even if there is a high loop or air-gap device. If your jurisdiction follows the UPC, an above-the-flood-rim air gap device is required, regardless of the built in features. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
If the dishwasher drain piping looped higher than the bottom of the sink I would not have called it out (1980's condo). Although with an 03 remodel an air gap probably should have been installed. When I explain it to clients I tell them if the disposal backs up, without loop or air gap, you may not be aware of it as the waste will drain into the dishwasher. With a loop or air gap you will become aware as the sink will backup. |
I have found that the ones with "built in" air gaps have the drain line routed through the top of the (cabinet) instead of being routed through the bottom, easy to figure why.
Check #'s and call to be sure. |
I remember looking through the manual on a new unit and finding something about the internal drain having a high loop. I can't remember the brand. I think most units have a solenoid valve or check valve to prevent backflow into the supply line. No high loop needed for that. |
If the top of the loop is not higher than the flood rim, i.e., somewhere between the bottom of the sink and the top of the flood rim, then there still is the possibility of contaminated water backflowing into the dishwasher. NACHI 2005 U.S. Member of the Year
A built-in high loop on the drain/waste side would require removal of the dishwasher to clear a blockage. There are some "higher end" models with built in disposals that drain debris quite effectively, however, in our state, they still require an air-gap. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Blockages would not occur in the drain line itself unless someone has removed the strainer or screen in the bottom of the dishwasher. It would be possible for debris to come from the sink direction I guess but dishwashers have a pump to force the water out. |
| No high side | Alan Dow | Inspecting HVAC Systems | 2 | 8/22/07 2:47 PM |
| Drip Loop | chunt1 | Electrical Inspections | 5 | 1/31/07 6:52 AM |
| High Radon Test Results | gbrasseur | Miscellaneous Discussion for Inspectors | 11 | 9/19/06 8:49 AM |
| Loop Vent | Charles Bottger | Plumbing Inspections | 22 | 2/19/06 12:32 AM |
