Old 10/12/08, 10:56 PM
lynn zhou lynn zhou is offline
Please Note: lynn zhou is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default high water pressure
I recently put a pressure gauge on my water heater drain faucet, I got 140. That is the reason the TPR valve is dripping.
At first, I thought it was due to thermal expansion from the water heater.
The pressure would go down to 40 as soon as I turn on the cold water faucet. The pressure would creep up after I turn off cold water. Note, the water heater wasn't heating because I only turned on/off the cold water.
That means the pressure isn't from thermal expansion, right?
Does that mean my street water pressure is too high?
I have pressure regulator in my house. It reads 25-75.
So what is the problem???
Old 10/12/08, 11:06 PM
Dale Duffy's Avatar
Default Re: high water pressure
Sounds like you need a new Pressure Reducing Valve....but I am not a plumber, which is who I would recommend looking at the issue, and repair as needed.
Old 10/12/08, 11:07 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Regulator isn't regulating...... The water to the water heater. Spring type regulators sometimes get stuck. Take your guage and put it on a sillcock to test house pressure. If it is high also then have service on regulator or replace.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 10/12/08, 11:14 PM
Thanks for your suggestion. I will try it on sillcock tomorrow.
But I thought it should be the same as they are all connected together.
Old 10/12/08, 11:20 PM
Without knowing what the system looks like there is no way for me to say that all water is reduced. Since when you turn on the cold the press. drops the entire water system is probably connected to one faulty press. regulator.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 10/12/08, 11:25 PM
Dale Duffy's Avatar
Hard to believe there is 140 lbs. at the street, now that is really off base.
Lynn, are you sure the pressure gauge your using is reading correctly?...I think I would try a couple different pressure gauges...that is really odd.
Old 10/12/08, 11:45 PM
Dale I've seen it about that high south and east of Dayton, so I guess I just took it for granted.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 10/12/08, 11:49 PM
Jeffrey R. Pope's Avatar
My street pressure is 160 psi.
Your regulator is bad, plain and simple. The label that reading of "25 - 75" is just the range of the regulator - when it's functioning properly.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/13/08, 12:25 AM
Dale Duffy's Avatar
160 lbs unreal....
Getting any Fire or Smoke up you're way Jeff?----
Old 10/13/08, 12:28 AM
Dale Duffy's Avatar
When I was in the Underground Pipe Business, water, sewer, storm, large diameter pipe, 4 in. to 60 in.....I only tested PVC or Transite at 190 lbs, and if there was a pocket of air in a pipe, I have seen the pipes come right out of the ground and tip a car on its side (after the pipe failed) when I was testing the pipe for the City inspector....!!!
Old 10/13/08, 1:41 AM
Christopher Currins's Avatar
Wow, that's amazing Dale. Good thing it was the car and not you.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 10/13/08, 1:02 PM
No smoke here. We're about 15 miles north/west of this one. Freeways are sure tied up though.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/13/08, 9:12 PM
The pressure gauge still reads more than 145 on the outdoor sillcock. So the problem IS water pressure from street is TOO high.
Is the water company's responsibility to set the proper pressure when connect to my home?
The pressure regulator (the failed one) is connected before water meter. Does this belong to water company or mine? I called my water company, but I don't know when will they show up.
Any estimate to replace the regulator if I call plumber from yellow page?
Old 10/15/08, 11:22 AM
The regulator is your responsibility.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/15/08, 8:50 PM
Thanks Jeff. Do you mean it's mine even if it's before the water meter?
So the water company is not responsible for regulate the pressure? No wonder they still have shown up yet.
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 7:31 AM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 10:18 PM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 10 1/11/06 10:53 PM
