Old 12/31/08, 3:30 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default Hole in slab
These pics are from my sisters house. This is an opening about 1 1/2 inches that opens to about 3-4 inches and is about 15 inches deep. The lip is threaded, and about 2 inches below the lip is an opening in the side. When we get a heavy rain she gets water bubbling out of the hole onto the floor. I suggested that she cap it. But I am wondering about the purpose of the hole. The house is over 100 years old and was a farm house at one time. She does have a sump that was installed many years ago but is not attatched to a drain system, it just collects what flows through the ground.
hole-slab-basement-hole-001.jpg   hole-slab-basement-hole-002.jpg   hole-slab-basement-hole-003.jpg
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Old 12/31/08, 4:24 PM
Barry Adair's Avatar
Default Re: Hole in slab
no idea of what this could have been for
but if water percolates as suggested capping will increase hydrostatic pressure under the floor and may cause cracking, floating and/or structural damage
we've had pools and tanks float out of the ground and all of the pools i've ever built have had a hydrostatic relief at the main drain
you may want to consider this before capping
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/31/08, 4:26 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is this in a basement? or slab on grade?
Old 12/31/08, 4:27 PM
Hi Barry,
Good points. BTW I lived in Garland for 8 years, Mill Creek Crossing, Miller and Centerville. Left in 2002.
Michael Merino
Old 12/31/08, 4:28 PM
It is in the basement.
Michael Merino
Old 12/31/08, 4:29 PM
rmaday's Avatar
Could simply be a floor drain without a screen.
Does that horizontal run go to the sump?
Old 12/31/08, 4:32 PM
You got me thinking. Any chance this IS a hydrostatic relief to that the floor wouldn't crack?
Michael Merino
Old 12/31/08, 4:38 PM
Does not run to the sump. It is only about 15 inches deep and the opening is only 1 1/2 inches wide but increases to 3-4 inches wide after the threads.
Ok the more I think about Barry's and Rick's response I got this idea about what it could be.
When the house was built 100+ years ago, I am sure it was a dirt floor. It did not have a sump pump. The concrete floor was added some time later without a sump pump or any drainage tiles. The hole was put there to relieve the hydrostatic pressure, to protect the floor from damage. The sump pump was added about 12 years ago and only drains whatever water seeps through the dirt, it is not connected to any drainage system.
What do you guys think?
Michael Merino
Old 1/1/09, 9:25 AM
standard report verbiage...
This inspection and report is based upon a visual non-invasive general inspection of the subject property. It is a snapshot in time, only while the inspector was onsite and is incapable of reciting previous events or predicting future events.
that being said the appearance of water in the middle of the basement floor around this opening leads me to believe the exterior and sub terrain drainage along with the sump system are not performing their intended function and require immediate evaluation for further repair...otherwise she'll continue to have a mess...you can fill in the rest
hth
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 1/1/09, 9:40 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Is it an air vent for a cristern?
Old 1/1/09, 4:36 PM
Harry E. McClard's Avatar
Harry E. McClard Harry E. McClard is offline
I agree with Barry. I've run across things that look exactly like that in some of the 1800's houses up here that had newer concrete floors (probably poured 50+ years ago though). They look like old drain lines and none of them has had any cover on them. The last one I saw, about a month ago, I tried to get my boroscope into it but it was not long enough to see anything; went out to the van and got my electric fish and ran it in until it banged on something that sounded like an iron pipe T so there had to be more stuff under there that I couldn't see. Still think they are old drain "whatchamacallits". Haven't found much in old plumbing archives on the web though.
Harry "Bud" McClard
Serving All of New Hampshire
Old 1/2/09, 4:45 PM
tphillips's Avatar
tphillips tphillips is offline
Looks like a drain tile system that has degraded to the point of water flowing backwards when it rains. Had this problem in an old house I once owned. Ended up digging it up, filling the pipe with concrete and putting in a sump pump system. Solved my wet basement probs.
Tom
Old 1/2/09, 11:04 PM
Frank J. Carey Frank J. Carey is offline
Many of the older homes here have them. Just a simple floor drain that either dumped into a bore hole or tapped into the sewer. Based on the location of the house my guess is either bore hole or back yard somewhere. Regardless, it is no longer serving its intended purpose as something must be clogged/damaged downstream.
Frank
Carey Inspection Solutions, LLC
Wilkes-Barre/ Scranton PA
Nachi ID -> 08022204
Frank@careyinspectpa.com
www.careyinspectpa.com
www.frankcareyconstruction.com
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
supply in slab or walls? jeubank Plumbing Inspections 1 7/8/06 10:36 AM
