Old 2/2/06, 5:03 PM
tneumann's Avatar
tneumann tneumann is offline
Default Homeowner special....defect or just informational?
I have seen these a lot..I used to see them in the Phoenix area utilized for supplying water to the swampers....this one has been tapped for the ice maker...do you guys generally write this up as a defect or something to keep an eye on? I have never seen one that wasn't leaking...but this one looks fairly new...my bro n law says he didn't do it I'm not sure I believe him....
Old 2/2/06, 5:16 PM
gbeaumont's Avatar
Default Re: Homeowner special....defect or just informational?
Hi to all,
Tony, like yourself I have never seen one that didn't leak at some point, personally I loath the things, I would write it up as an area for monitoring in future.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 2/2/06, 5:21 PM
Brian E. Kelly's Avatar
If it is not leaking when I inspect it then I do not write it up. I have not seen a piping system yet that will not leak. If you do not believe me, open the yellow pages to plumbers.
Old 2/2/06, 11:51 PM
bemelander bemelander is offline
Tony,
If its not leaking I don't report. I may give a verbal to the client and explain what it feeds but that's it.
I have two of these valve one is about 18 years old, feed the whole house humidifier, was turned of 5 years age, never leaked. The other I installed for the ice maker 5 years ago, never leaked.
Bill
Bill Emelander
Professional Edge Home Inspection
Grand Rapids and all of West Michigan
NACHI #03111914
www.proedgehi.com
Old 2/3/06, 1:43 AM
JLilly's Avatar
JLilly JLilly is offline
I've installed a bunch of those things going to furnace mounted humidifiers. The saddle valve comes with the humidifier usually. I wouldn't call it a problem, just monitor. They dont usually leak if you make sure the packing on the stem is tight and clean the surface of the pipe well before tightening it down.
Old 2/3/06, 3:29 AM
jkormos's Avatar
jkormos jkormos is offline
The saddle valve will leak, just when. Although if it is not leaking now, it needs to be monitored, not a best practice, but should recommend to budget for future replacement.
Joe
Old 2/8/06, 8:27 AM
mnye mnye is offline
I would advise that it be monitored, I have worked in commercial buildings where these were installed, and over time they can cause problems. I will not use them in my home.
Mike
Old 2/9/06, 3:32 AM
When I see them, I report that they should be monitored. I often see what appears to be galvanic corrosion on them.
An other Homeowner special mcyr Exterior Inspections 5 9/15/07 3:08 PM
U.S. Homeowner Woes Felt Around World jburkeson1 Miscellaneous Discussion for Inspectors 0 8/12/07 11:36 PM
Free Happy Homeowner Manual w/purchase of Inspect & Protect. July 4 SPECIAL! gromicko Special Discounts for InterNACHI Inspectors 0 7/3/07 5:28 PM
