gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Gang,
I am sure there is a good explanation for this, I have just never seen it before. This hose (garden hose) goes from the copper plumbing piping into the floor drain. Sorry the one pic is sideways, I can't figure how to do it differant. The house has a newer A/C and furnace. What is this hose for? Thanks in advance. |
Maybe to drain the supply system upstairs for servicing?
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
That was one thought I had Stephen. Just not sure.
I don't see a dirt leg for the water heater. Are they required in your area? |
Does the home have underground sprinklers?
The draincock that the hose is attached to may be to back drain the line from the shutoff valve to the vacuum break on the outside of the house to prevent freezing. Hose is just a convenience to get the draining water to the floor drain. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Without seeing the "whole picture", it's hard to say. It could be a drain for the system. it could be a washdown hose,,,
I agree with Larry...if the home has U/G sprinklers, I see a lot of folks doing that for two reasons. One as Larry suggested, and the other is because the Main Gate valve to shut down the U/G's for the season, isn't holding. It allows a dribble to pass by the shut off valve and this is a way of letting the seepage to go to the drain, instead of having to empty buckets or letting the lines fill up again over the winter months and freezing/breaking a line.
Gate valves are famous for seepage. Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Bonding Piping 101....Good To Know ! | pabernathy | Electrical Inspections | 37 | 4/28/07 11:25 AM |
| Exterior copper piping | dbucknavich | Plumbing Inspections | 9 | 6/27/06 2:05 PM |
| Looking for comment by Caoimhín P. Connell | phinsperger | Ancillary Inspection Services & Additional Topics | 2 | 2/18/06 11:22 AM |
