Old 1/28/07, 4:38 PM
Rafael Rafael is offline
Please Note: Rafael is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default hot shower
Everytime a toilet is flushed or a sink is used while the shower is on that person gets hot water only! ouch! Please advise to the cause.
Old 1/28/07, 4:55 PM
staylor5's Avatar
staylor5 staylor5 is offline
Default Re: hot shower
The shower controls are old. Newer models have ways to determine the difference in hot and cold water and adjust it accoringly. There are no electronics involved, just special valves.
Old 1/28/07, 5:49 PM
So you dont think its because bad venting ? what is the test for
bad venting anyway is it turning on shower , sink and flushing toilet at the
same time and if there is suction of some king on the shower or sink its
the venting system
thanks
Old 1/28/07, 9:39 PM
David P. Valley's Avatar
Could be low water pressure.
Old 1/29/07, 12:47 AM
Brian E. Kelly's Avatar
http://hometips.com/cs-protected/guides/scald.html
Old 1/29/07, 6:17 AM
staylor5's Avatar
Bad ventind or lack of a vent would cause the water to drain slower. The vent only involves the drain line. This would not affect the high pressure line. I'd bet my life that its the mixing valve.
the venting system
thanks
Old 1/29/07, 6:55 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
If older house it could be the galvanized pipes or a mix of copper & galvanized pipes... The pipes corrode from the inside-out.
On a well, could be a buildup of minerals inside the pipes & mixing valves.
Old mixing valves can even have chipped valve seats & chipped washers that reduce water flow.
Low water pressure: Bad pipes, Bad Valves, Bad Mixers, Well situations
Poor venting: Sink and tub drain slow, toilet does not flush with one flush
These are just possible indicators. Other situations could be the cause also. eg: hair clogs, etc.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 1/29/07, 12:59 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
A preasure ballanced valve would help with this situation. The valve adjusts itsself when a fluctuation is temp occures. You may feel a reduction in water preasure but not the hot/cold difference.
Without one it's a good way to tell the kids to get out of the hour long shower. Just flush the toilet a few times.
Old 1/29/07, 1:02 PM
Are there both a hot and cold control valve to operate the shower?
Or just one valve?
Low water usage shower head - squirts lfoster Plumbing Inspections 4 6/2/07 12:40 PM
Shower stall light/fan on garage GFCI lprinzi Electrical Inspections 3 10/31/06 4:13 PM
Bait, Bites and Shower Doors tmantsch Miscellaneous Discussion for Inspectors 2 5/4/06 4:52 PM
Weep Holes in Shower Stalls? ebeahm1 Miscellaneous Discussion for Inspectors 9 3/31/06 1:10 PM
