Hey everybody I inspected a gas water heater on a new construction yestarday. The heater is in a dedicated enclosure connected to the house. The water heater sits on the ground but should be on a pedestal. The builder is arguing that because it is not in the house or garage that it does not need to be 18 inches off the ground. My take is that it is still a gas water heater and should be 18 inches off the ground. The enclosure is connected to the master bath which is connected to the master bedroom if the water heater explodes so does the master bath and bedroom. So am I correct in saying it should be up off the floor. Also they didn't connect the TPR discharge pipe.
Check the manufacturer's installation spec for the particular model.
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
As Joe suggested, check the manuf specs, but generally speaking, it is not required to be raised unless it's in the garage. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
This may help. I could not upload the whole file because it was too big.
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Y'all got me worried there. My old water heater sits straight on the floor in the basement.
But I'm probably still not code compliant. I do not have a dedicated drain for the TPR valve or a drain pan. But there's nothing to damage down there. And it does look like an example of another silly rule. 18 inches above ground or not, in a garage if a car hits it, it's gonna make a mess. |
The 18 inch rule isnt really for fear of cars hitting it. The reason it is 18 inches off the ground is because gases can collect low on the floor and create a combustion hazard with the burner of the hot water heater then boom there goes the garage.
That should apply to unfinished basements as well then. I have paint, a mower and a small amount of gasoline in mine (kept well away from the furnace and water heater). I know I should move the gasoline.
You know i have seen water heaters sitting on slab etc...But the truth be told you loose energy as well as the bottom of the water heater will deteriorate faster on a electric water heater sitting on floor.Should sit on catch pan (recommend in my reports).Gas should be elavated due to flamable fumes always fall to the lower 4 to 6 inches from the floor.(hair spray,air freshner etc......Flammable products!
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
Plumbing codes (...at the least the IPC/IRC....California uses the UPC) do not require water heaters to be raised 18 inches unless they are located in a garage or a room accessed from a garage.
The reason is that gasoline vapors are denser than air and hover near ground level. Keeping the ignition source at least 18" above the floor reduces the chances of igniting gasoline fumes. The 18" requirement applies to electric water heaters as well. There is no such requirement to raise a water heater above floor level in any other part of a house. |
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| Hot water heater question | carolinainspector | Plumbing Inspections | 9 | 6/19/06 1:59 PM |
