A 2004 Bradford & White water heater has a pressure valve off the hot water copper line above the tank with a small diamater line extending to the ground.
Should this valve be removed? If yes why? If no how come? |
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Did the tank itself have a TPR valve installed correctly? |
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
That relief valve is worthless.
Jason asked the important question. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Would you advise removing the worthless one? |
Maybe the installer thought it would make a crude air arrestor??? weird... |
It's an unnecessary component, subject to failure over time. It would be fairly simple to just cap it off, which would probably be my recommendation. . .
| TPR valve | acox | Plumbing Inspections | 19 | 5/27/07 12:36 PM |
| Hot Water Tank - missing Pressure relief valve? | Jan Lombard | Plumbing Inspections | 31 | 4/12/07 3:32 PM |
