Hot water tank is in a poor placement. There is no room for mantenance. natural gas furnace in the same room. Maybe six by eight.
Tank right behind the natual gas furnce. A small inclosed furnice room. The TPV leg is missing. If the pipe is instaled it would be at a very poor location. 36 inches away from the furnace burner. Question. Code on hot water tanks. I could only find pans and the regular stuff. #1 Can the be in a mechanical room with a natural gas furnace. An inspection last year had hydro quebec move the tank outside the oil furnice room that was bigger than this one. Thanks in advance. What do you do when you run into the shaq (flip) from hell. I am speeding countless hours and do not want to refer. Can some one bring me a coffee. Montreal Home Inspection Services Inc. 3510 Benny ave. Suite # 401 MONTREAL Qc. H4B 2R8 Inspecteur Professionnel Certifié en Bâtiment - Certified Home Inspector(CHI) (CHI) InterNACHI Certification ID: NACHI10030603 ACHI Certification ID: ACHI100014 montreal-home-inspection-services.com home-inspectionservices.com home-inspectionmontreal.com Don't get what you paid for Montreal, "Get what you need." Chapter president. Montreal INACHI Peer Group Chapter. |
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I quite typically see the HWT and furnace in the same mechanical room. I know of no rules against it providing there is proper ventilation.
jfunderburk is a non-member guest and is in no way affiliated with InterNACHI or its members.
2009 IRC
"SECTION M1305 APPLIANCE ACCESS M1305.1 Appliance access for inspection service, repair and replacement. Appliances shall be accessible for inspection, service, repair and replacement without removing permanent construction, other appliances, or any other piping or ducts not connected to the appliance being inspected, serviced, repaired or replaced. A level working space at least 30 inches deep and 30 inches wide (762 mm by 762 mm) shall be provided in front of the control side to service an appliance. Installation of room heaters shall be permitted with at least an 18-inch (457 mm) working space. A platform shall not be required for room heaters. Code commentary: Because mechanical equipment and appliances require routine maintenance, repair and possible replacement, access is required. Additionally, manufacturer’s installation instructions usually contain access recommendations or requirements. As a result, the provisions stated herein supplement the manufacturer’s installation instructions. The provisions of this section specify that access must be provided to components that require observation, inspection, adjustment, servicing, repair or replacement. Access is also necessary for operating procedures such as startup or shutdown. The level working space in front of the control side of the appliance must be 30 inches (762 mm) wide and 30 inches (762 mm) deep to provide adequate space for the technician or inspector to safely perform the work. The code states that “accessible” means “access that might require the removal of an access panel or similar removable obstruction.” An appliance or piece of equipment is not accessible if any portion of the structure’s permanent finish materials, such as drywall, plaster, paneling, built-in furniture or cabinets or any other similar permanently affixed building component, must be removed before access is achieved. In addition, removal of all or part of another appliance or the piping or duct or serving other appliances must not be necessary to perform the service, replacement or inspection of an appliance. Such an installation could result in unnecessarily high costs to the homeowner and improper or unsafe reassembly of other appliance and system components. This could also result in service personnel having to perform disassembly and reassembly of appliances and system components that are not within the personnel’s area of expertise or licensed work. The intent is to provide access to all components such as controls, gauges, burners, filters, blowers and motors that require observation, inspection, adjustment, servicing, repair or replacement." "2009 IRC P2801.3 Location. Water heaters and storage tanks shall be installed in accordance with Section M1305 and shall be located and connected to provide access for observation, maintenance, servicing and replacement." |
Thanks Joe.
Mechanical equipment needs maintenance therefor a reasonable amount of free room for qualified trades to work. I recommend a licensed professional evaluate the tanks work space installing the TPV leg. I did not have that code. In the vault. Thanks everyone. Montreal Home Inspection Services Inc. 3510 Benny ave. Suite # 401 MONTREAL Qc. H4B 2R8 Inspecteur Professionnel Certifié en Bâtiment - Certified Home Inspector(CHI) (CHI) InterNACHI Certification ID: NACHI10030603 ACHI Certification ID: ACHI100014 montreal-home-inspection-services.com home-inspectionservices.com home-inspectionmontreal.com Don't get what you paid for Montreal, "Get what you need." Chapter president. Montreal INACHI Peer Group Chapter. |
See manufacturer's installation instructions which is usually written on the appliance.
e.g.: http://www.johnwoodwaterheaters.com/Docs/Manual%202.pdf Marcel Gratton, NACHI04011210, CMI, NHI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Marcel you ever tear files. folders and the internet apart looking for that fact only to find what your looking for under your nose.
Manufactures instructions. Man am I a case some times. Serial and model numbers are always photographed. Thanks mate. All the best. Montreal Home Inspection Services Inc. 3510 Benny ave. Suite # 401 MONTREAL Qc. H4B 2R8 Inspecteur Professionnel Certifié en Bâtiment - Certified Home Inspector(CHI) (CHI) InterNACHI Certification ID: NACHI10030603 ACHI Certification ID: ACHI100014 montreal-home-inspection-services.com home-inspectionservices.com home-inspectionmontreal.com Don't get what you paid for Montreal, "Get what you need." Chapter president. Montreal INACHI Peer Group Chapter. |
Its electric HWT.
As mentioned, a HI last year had Hydro Quebec installing the electric HWT out side in the garage due to an oil furnace in the small utility room. #1 The TPV discharge had to be xx from gas and oil furnaces said the technician. #2 Space for maintenance as Joe mentioned was another point of several codes they cited. I'll try to get the scope in Quebec Marcel. Montreal Home Inspection Services Inc. 3510 Benny ave. Suite # 401 MONTREAL Qc. H4B 2R8 Inspecteur Professionnel Certifié en Bâtiment - Certified Home Inspector(CHI) (CHI) InterNACHI Certification ID: NACHI10030603 ACHI Certification ID: ACHI100014 montreal-home-inspection-services.com home-inspectionservices.com home-inspectionmontreal.com Don't get what you paid for Montreal, "Get what you need." Chapter president. Montreal INACHI Peer Group Chapter. |
The furnace may need more space but then again clearance requirements are usually written on the furnace data plate. I am not aware of any distance requirements for the TPR valve to furnace, only that it should terminate above floor about 8 inches. As for installing the electric WH in the garage, I would be concerned if the garage isn't heated. Marcel Gratton, NACHI04011210, CMI, NHI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| hydronic radiant floor heat on hot water tanks | mnicholet | Plumbing Inspections | 7 | 4/14/10 5:48 PM |
