Old 8/22/07, 11:25 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Hot water temp.
tested at 140 degrees, what would be normal range.
David
Old 8/22/07, 11:30 PM
Michael R. Boyett's Avatar
Default Re: Hot water temp.
Most mfg recommend between 120° to 125°. Some inspectors like to see higher to combat bacteria, i.e. Legionnaires, etc. I stick with 120°
Old 8/22/07, 11:45 PM
Joseph Hagarty,  CMI's Avatar
120 unless a tempering valve is installed on the outlet of the water heater.
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 8/22/07, 11:50 PM
Rick Maday Rick Maday is offline
Please Note: Rick Maday is a non-member guest and is in no way affiliated with InterNACHI or its members.
David
Scalding potential if higher than 120.
How did you test it? IR them, mercury, probe?
How long did it take to get to 140?
Where at kitch, tub, all fixtures?
Just curious.
Old 8/23/07, 12:07 AM
Roy D. Cooke, Sr's Avatar
David
We write up all water temp any over 120 F needs immediate adjustment.
Below is a chart that tells how fast you can get burnt. ( F )
........... Cookie
52 (125) 2 min
*Usual temperature of home water heaters.
55 (131) 20–30 s
60* (140) 5–6 s
66 (151) 2 s
70 (151)
Temperature,
°C (°F) Exposure time
1 s
44 (111) 6 h
49 (120) 9 min
51 (124) 2–6 min
Table 1: Exposure time at given temperatures that
causes deep second-degree burn injury in adults
Old 8/23/07, 2:40 AM
Thanks everybody for the info...
Old 8/23/07, 8:09 AM
wsiegel wsiegel is offline
Temperature Time to Produce 2nd & 3rd Settings Degree Burns on Adult Skin
160°F (71°C)
About 1/2 second
150°F (66°C)
About 1-1/2 seconds
140°F (60°C)
Less than 5 seconds
130°F (54°C)
About 30 seconds
120°F (49°C)
More than 5 minutes
80°F (27°C)
Old 8/23/07, 9:26 AM
I use 125, as stickers on some brands of water heaters use this temperature.
Tough to say, turn it down to 120 when the manufacturer says 125.
Abraham Lincoln
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 10 1/11/06 10:53 PM
