This is actually at my own home. I knew this day would come where the main water feed line would require replacement.
Seems in 1971, in order to save a few bucks, the builders in our neighborhood decided to run a six foot copper line from the meter to, a 20 foot line of galvanized pipe, and then to another six foot piece of copper pipe to the home. It is all now 1 inch PVC. |
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
yikes
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Look at the bright side, you'll have much better water pressure now.
Are you saying Eric's problems may have just begun.
Let's just say he's been running at restricted/reduced pressure for how long??? Now going to 1" at full pressure! Need I say more?
There aren't any other "weakest links" as the rest of the system is all copper.
The first picture actually happened when I was talking to my neighbor. The line was already exposed and while we were talking, we heard a swoosh sound and looked over and saw that the pipe had started to leak. The pressure wasn't really the issue,it was more flow. I knew when I bought the home 13 yeas ago that at some point, I would have to change the line as I knew the neighborhood had poor water pressure. I was just surprised that they took the time to do it the way they did. It probably cost more to do it that way than to just run one continuous copper line. Now, you can run every fixture in the house and there is no loss of pressure. The days of my little prank on the wife, of flushing the toilet while she is in the shower, are gone. I'll have to come up withe some other prank! |
Remember, you heard it here first! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
What kind of time limit and for how much would you like to wager?
The water pressure isn't like it is in some areas where they need a regulator. |
I can't tell you how many times I've seen it... increase the flow or pressure on a system thats been deficient for a period of time, and whammo... leaks start springing up everywhere. Just my personal observations. Take 'em, or trash 'em. I don't really care. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Jeff, it could be worse, water lines up here are 6'-8' deep. Now that would suck.
The pressure in my house is 92# and I still haven't installed a pressure regulator. I know, some day I will pay for it. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
A little trash in the shut off valves or aerators, which I have already cleaned out, but that was about it. |
Ours is barely 60 lbs. |
Ditto here... mine comes in about 12 inches below the slab (full basement- 7 ft headroom). City replaced with plastic about 5 years ago. (Meter's in basement here).
| Drain problem | bhartley | Plumbing Inspections | 8 | 10/5/09 10:32 PM |
| Weird water heater problem | kweiss | Plumbing Inspections | 3 | 4/5/09 6:34 PM |
| furnace problem ? | Aaron lore | General Inspection Discussion | 11 | 2/5/09 1:04 PM |
| Internet browser problem | bking | Miscellaneous Discussion for Inspectors | 33 | 1/26/09 1:45 AM |
| I have a problem | cbottger | Electrical Inspections | 17 | 1/20/09 4:45 PM |
