Old 5/4/06, 6:00 PM
mmorgan mmorgan is offline
Default Hub vents in attic
I've seen two of three of these before, but they have always been used for sinks that are on an island. I've never seen them in attics before. Can someone tell me if there is a problem with using these in attics?
Thanks,
Mike
Old 5/4/06, 6:08 PM
Jeffrey R. Pope's Avatar
Default Re: Hub vents in attic
AAV's can be installed in attics, however, they are required to be at least six inches above the insulation.
P3114.4 Location. Individual and branch air admittance valves shall be located a minimum of 4 inches (102 mm) above the horizontal branch drain or fixture drain being vented. Stack-type air admittance valves shall be located a minimum of 6 inches (152 mm) above the flood level rim of the highest fixture being vented. The air admittance valve shall be located within the maximum developed length permitted for the vent. The air admittance valve shall be installed a minimum of 6 inches (152 mm) above insulation materials where installed in attics.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/4/06, 6:11 PM
tneumann's Avatar
tneumann tneumann is offline
Knowledge is power..thank you Jeff Pope.
Old 5/4/06, 6:35 PM
Thanks Jeff!
I didn't even know the correct name for them. I sure appreciate the info.
Mike
Old 5/4/06, 9:09 PM
Pardon my French, but if this is a Mechanical Vent, my jurisdiction will not allow it uless it is a re-modle job or some type of renovation that it is not possible to vent the proper way.
Check your Local AHJ for this subject.
If I am wrong, tell me. Hard to tell from the picture.
Marcel
Old 5/5/06, 9:16 AM
This is a remodel job. The house burned a couple of years ago. It is also in a small town with no code enforcement and its also possible that this is the original plumbing.
Old 5/11/06, 1:17 AM
tnoisaw tnoisaw is offline
Please Note: tnoisaw is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is an autovent. What I see as stated here should be higher but if someone took the time to go into the attic then they should have tied into the vent that was there. If you come across these they can leak with blockages and make a noise when water drains. They are sealed on the treads with teflon tape and pipe dope. This particular vent is not legal under some codes so a check with your local juristiction may be required.
Tony
Old 5/12/06, 6:27 PM
dgagne1 dgagne1 is offline
that particular vent is called a pro-vent and is not legal in comparison to the air admit. valves allowed in the newer IRC. This one can fail because it works with both pos. and neg. system pressure. If they are in the attic, they should have just vented thru the roof or back vented it to the exisitng vents. AAV are only a last resort when no other option is available with the inspectors approval. I would suggest at least replacing it with the proper AAV.
Old 5/14/06, 10:38 AM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Everyone seems to be missing the obvious. If the thing is in the attic in the first place, why not vent to the outside? It is not that hard to cut a hole in the roof covering and put in a proper vent.
Larry
Old 5/14/06, 11:47 AM
Makes to much sense Larry. ha. ha.
Marcel
Old 5/15/06, 7:14 AM
Mike Parks's Avatar
Mike Parks Mike Parks is offline
Please Note: Mike Parks is a non-member guest and is in no way affiliated with InterNACHI or its members.
As Daniel said that is not an approved AV.
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 7:29 PM
Outdated ceiling vents to attic rray Structural Inspections 2 1/31/07 6:47 AM
Attic ventilation question pdoane Interior Inspections 8 8/27/06 2:22 PM
Attic Inspection rbritton Electrical Inspections 19 8/2/06 2:58 PM
