Old 11/23/06, 8:52 PM
gporter's Avatar
gporter gporter is offline
Default Humming
When the water is not running we hear a humming sound coming from the pipes. On the other side of the wall is my daughters bedroom. When I turn the water on it stops. Any thoughts. It has been going for a couple of weeks. Until today I thought it was the neighbors HVAC. Any thoughts?
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 11/23/06, 8:58 PM
Dale Duffy's Avatar
Default Re: Humming
Have a high pressure leak when the water is off????
Did you feel the pipes anywhere Gary, see if you can feel water moving or causing a small vibration???
Other than small amounts of water moving in the pipe causing the noise, it's all I can think of right now.
Old 11/23/06, 9:03 PM
Donald R. Peterson's Avatar
Donald R. Peterson Donald R. Peterson is offline
Default Re: Humming
My first thoughts are:
-a slow leak- toilet, pipe, ice maker, reverse osmosis, something consuming water
-A water softener
-Thermal expansion of pipes or the refilling of an expansion tank
-water pressure regulator, if water is being consumed
-during the hum check the water meter for consumption
Don Peterson, CMI
AmeriDream Home Inspections Inc.
NYS License: 16000014560
Old 11/23/06, 9:47 PM
ekartal6 ekartal6 is offline
Please Note: ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Humming
If you would have said a loud vibtraion that sounds like it's passing from one area to another, I would have said it may be a defective flush valve that is creating a water hammer.
Old 11/23/06, 10:26 PM
Roy D. Cooke, Sr's Avatar
Default Re: Humming
He said water not running .
I wonder is this a new home or have you lived there for a while .
What new has gone on around you a new radio station or TV a new Hydro tower? A new Ham radio operator ?
I would like more information to give thoughts to . Roy Cooke
Old 11/24/06, 6:03 AM
gporter's Avatar
Default Re: Humming
Roy it is 4 years old
Gary Porter
321-239-0621
Old 11/24/06, 1:31 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: Humming
toilet
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 11/24/06, 1:42 PM
kkenny's Avatar
kkenny kkenny is offline
Default Re: Humming
1st check the the meter, if everything is off and your meter is running "LEAK".
If not check to see what else is running when the humming is on. Sump or extractor pump, HVAC, H2O heater, well, etc.
Is your home a house or duplex,townhome, condo? You mentioned you thought it might be from your neighbors.
Also check your supply pipe maybe the hum is coming into your house from the supply line.
Kevin
Kevin M. Kenny, Sr.
Kenny Home Inspections
Oak Forest, Illinois 60452
Nachi #6070990
http://kennyhomeinspections.com
Old 11/24/06, 5:56 PM
gporter's Avatar
Default Re: Humming
Kevin 2 story home
Gary Porter
321-239-0621
Old 11/24/06, 6:06 PM
Default Re: Humming
It's the wondering that creates it...
Hmmmmm....
Larry Kage, CMI
231 929 3525
Old 11/25/06, 7:38 AM
Barry Adair's Avatar
Default Re: Humming
Are the shower heads and wall fixtures secured?
We had some loose pipes (never strapped properly) at the tub and shower areas. I backed the escutcheons away from the wall tile, put a temporary wedge to hold pipe in place at desired location, and sprayed some insulating foam inside the cavity. Once dried no more rattle. Remove wedge, replace and seal escutcheons.
I've also seen attic installed HVAC equipment suspended from rafters cause vibrations heard at various locations inside living space. Had one last Tuesday that rattled only one kitchen cabinet door. Of course all of the ductwork was also lying across the ceiling joists.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/25/06, 3:43 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Humming
Turn all the toilets off. If you don’t hear noise turn toilets on one at a time to see if that is causing the noise. Also check flappers. You can see water going into the bowl at a trickle if the falpper is leaking through.
Old 11/25/06, 5:01 PM
gporter's Avatar
Default Re: Humming
Watson you solved it
Gary Porter
321-239-0621
Old 11/25/06, 7:31 PM
ldapkus ldapkus is offline
Default Re: Humming
He deserves a "green box"
Humming panel srowe Electrical Inspections 8 4/9/07 9:49 PM
humming thermostat fodette Electrical Inspections 3 2/6/07 7:35 AM
