Old 4/9/08, 4:54 PM
dsearcy dsearcy is offline
Default Humming in water pipes
Has anyone come across what sounds like humming (Not water hammering) in the water supply lines in a home. Even with the water off, it will sound like Tibetan monks at a morning gathering. And if you have what is the problem and fix for something like this. Thanks,
Don
Old 4/9/08, 7:22 PM
Bruce A. King's Avatar
Default Re: Humming in water pipes
The anti-backflow valves on exterior faucets can make a humming sound when the water is first turned off for a few seconds.
Is it occuring all the time?
Make sure the water heater TPR is not discharging a little bit somewhere.
www.BAKingHomeInspections.com
704 301-3207
Old 4/10/08, 12:56 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Does it have gate valves? If the gate gets loose in the valve the least little bit of flow can send one chattering. Oh sorry, plus what Bruce said.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 4/10/08, 7:48 AM
Russel Ray's Avatar
What Jack said.
I had one a few years ago that only hummed when the water inside was turned on, but it was at all faucets, tubs, showers, etc. Since I have had some experience with those nasty gate valves, I suggested to my Clients (and the sellers, who obviously needed to find another plumber) that it was the gate valve. They used my plumber who replaced the valve, solved the humming problem, and told them that every gate valve in the county should be replaced.
Old 4/10/08, 10:14 AM
jking2 jking2 is offline
If there is humming, there has to be flow somewhere. If there are no visible discharges, and there are under slab water lines, then it could be an underground leak, which could cause serious structural damage.
Jim King
Old 4/10/08, 3:53 PM
Good point, water is moving if it is making noise. What kind of heating system? Do they have a return on the HW line or a pump. Hopefully they don't have a leak. I chased a noise once in the water system, seemed like forever, and it turned out to be the transformer for the door bell attached to the same piece of wood as a cold water line. The hum was picked up by the water pipe and it sounded like a plumbing problem. Drove me crazy.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 4/10/08, 6:00 PM
ldapkus ldapkus is offline
Don
Are you in the San Fransisco Bay Area??? There have been recent pro-Tibetan protests and it just may be a morning prayer gathering.
Old 4/10/08, 7:03 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Toilet valves can hum when partially open with tiny particles.
It causes the sound to travel upline for some ways.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 4/10/08, 7:18 PM
Roy Horton Roy Horton is offline
try singing a few lines LOL
Old 4/10/08, 7:27 PM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Toilets are almost always the culprit if no water is being used, like John said.
The older type ballcocks with the long float rods.
Easy to check out, just push down gently on the float to locate which toilet is doing it.
I had a service call on one that was pretty loud that really frightened a lady one evening, she thought something was going to blow up.
Old 4/18/08, 10:11 AM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
Thant can be a bear to locate sometimes, any of the faucets or valves could have a torn washer that vibrates as water passes over it, causing the moan. as mentioned earlier toilet ballcocks, main gate valves, are some of the most common culprits. I just did one the other day and it was the cartrigde for the master shower.
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
