Old 10/27/07, 9:46 PM
Default Identify ABS defective pipe
How many have come across this type of pipe and know how to identify it.
Thought that this might help some as well as me on future identifications of the such.
What is ABS pipe?
ABS pipe is black rigid, non-pressurized plastic pipe used to drain your sinks, tubs, showers, toilet and washing machines. It is also used to vent the drain and waste pipes.
What is qualifying ABS pipe?
Qualifying ABS Pipe is pipe that:
  1. has creaked circumferentially adjacent to a joint or "fitting";
  2. has leaked; and
  3. was manufactured by one of the five defendant ABS pipe manufacturers during the relevant time frame.
There are five manufacturers of ABS pipe that for discrete periods of time between 1984 and 1990 that produced ABS pipe that allegedly may crack circumferentially at the joint. Those manufacturers and time periods are:
Centaur: January 1985 through September 1985
Phoenix: November 1985 through September 1986
Gable: Periodically between November 1984 and December 1990
Polaris: Periodically between January 1984 and December 1990
Apache: Periodically between November 1984 and December 1990
ABS pipe is marked on the outside wall of the pipe. The markings include the name of the manufacturer, references to code specifications and a date code. The date code, when translated, reveals the date the pipe was manufactured. Here are examples of how the pipe is marked:
To help you ascertain if you have the defective ABS pipe, please review the attached diagram:
Notice that the crack is adjacent to the joint and runs circumferentially around the pipe.
How to locate and examine ABS pipe:
  1. Attic inspection: The most accessible point to examine ABS pipe is usually the attic, where it serves as vents for kitchens, bathrooms and/or other sinks. The pipe can be horizontal or vertical. The vertical sections usually exit through the roof.
  2. Under sinks: The section of pipe coming out of the wall and connecting to the sink trap may be ABS. If the pipe is threaded or looks molded, then it is not ABS pipe.
  3. Crawl space: If your house has a raised foundation (has a crawl space under it), then pipe may be identified by looking underneath the house. This will usually give access to large amounts of pipe.
  4. Cleanout: If your residence has exterior cleanout, the name can sometimes be located at this point.
These are the easiest locations to inspect. Write down all markings on the pipe. This information must be included with you Registration Claim Form. ABS pipe comes in different diameters and is joined together by a variety of fittings. (See diagram below.) The configuration of the fittings, which come in all different shapes and sizes, is not relevant. ABS pipe is always black.
More tips for identifying qualifying ABS pipe:
Determine when your house was built.
ABS pipe is black rigid, non-pressurized plastic pipe. If your pipe is flexible or made of metal, such as copper, iron or galvanized steel, or carries pressurized water, it is not ABS pipe.
Qualifying ABS pipe was first manufactured in 1984. If your plumbing is older than 1984, it cannot have the qualifying ABS pipe.
Remember: Not all pipe manufactured by the defendant manufacturers during the period will crack and result in leaks. You may have pipe manufactured by one or more of the defendants that will not leak.
Hope this helps some.
Marcel
Old 10/28/07, 12:06 AM
Christopher Currins's Avatar
Default Re: Identify ABS defective pipe
Thanks Marcel, Good Info and nice diagrams.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 10/28/07, 12:33 AM
GARY L. RUSK GARY L. RUSK is offline
Thanks Marcel; very good info, I do most of my inspections on manufactured and modular homes, most use ABS pipe on the drain lines. From now on I’ll be taking more time checking the drain/waste lines.
Thanks again
Gary
http://www.hsspropertyinspection.com/
Old 10/28/07, 1:35 AM
gbeaumont's Avatar
Hi to all.
Here is a link to the site covering the class action suits for homeowners who have ABS drainage pipes.
http://www.abspipes.com/
From what I understand this problem mostly effects homes in the south west
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 10/28/07, 7:08 AM
Gary Oleski Gary Oleski is offline
Thanks Marcel.
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Old 10/28/07, 11:18 PM
gporter's Avatar
gporter gporter is offline
Thanks.
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 1/29/09, 7:39 PM
Thomas W. Schlotter Thomas W. Schlotter is offline
Thanks.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 36 10/27/10 11:21 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
Vent pipe dlee2 Plumbing Inspections 4 9/18/07 12:28 AM
Pipe hangers Ian Gills Plumbing Inspections 4 5/11/07 6:17 PM
