What is meant by a Indirect waste receptor when talking about a TPR valve.Does it mean that it is not connected to the drainage system of the home?
I inspected a home yesterday that had the discharge pipe routed horizontally with 3 -90 degree fittings before going vertical into a trapped standpipe with also other drain lines in it such as water softener. I am recommending they get re plumbed to go straight down to 6" from the floor but the is no floor drain. Nachi graphics show it going into a bucket. Is the bucket the indirect waste receptor & if so if the pipe was 6 " off the floor inside the bucket, couldn't that be a siphon situation also. Wouldn't the end of the pipe have to be 6" above the bucket to create the air gap? |
| Slope of waste drain line. | mlong | Plumbing Inspections | 5 | 4/23/08 9:54 PM |
| Waste line clean outs | tcrosby | Plumbing Inspections | 2 | 2/29/08 10:55 PM |
| Waste line on OUTSIDE of house | gkeene | Plumbing Inspections | 6 | 9/18/07 9:15 PM |
| Define "Indirect Waste Receptor" | jfunderburk | Plumbing Inspections | 5 | 2/18/06 5:35 PM |
